Quote problem in the DNS management section
Im on Version: 3.7.2 so im not sure if this has been fixed in the new versions after this.
When you use the DNS management section in the domain area, if you fill out a " (is used when you need to add an SPF record this is not working because instead to pass this variable as a " is passing as a &quot.
Im using Enom, so the way to test this is just add an spf record through whmcs or just put a "something" between quotes and then go to the Enom panel and you will see it as &quote something &quote.
Thanx!
