avalony Posted March 16, 2009 Share Posted March 16, 2009 Hi guys, I have always been in love with WHMCS. Especially after the move from ClientExec a couple of years back. However recently I have been experiencing really funny stuffs. Firstly, my WHMCS will just shutdown out of no where. I will get the error of ioncube 5.xxxx not loaded. I thought I have installed them earlier on? But after I have uploaded them again, things appear fine. And after a weeks, things change again. The error comes back again and I have to do the same thing again. I have asked the support to help me in this case and they added this to the htaccess: ==== suPHP_ConfigPath /home/gizdiskc/public_html/client ==== The ioncube error is solved. However now the system is unable to generate any invoice. I have customers complaining that they are unable to checkout their orders. No invoice is created and I received orders that have no value to them. Please advice. Thank you. 0 Quote Link to comment Share on other sites More sharing options...
openmind Posted March 16, 2009 Share Posted March 16, 2009 Is your MySQL database running in strict mode? If it is, switch it off... 0 Quote Link to comment Share on other sites More sharing options...
avalony Posted March 16, 2009 Author Share Posted March 16, 2009 Hi Phil, This is what I got from my server administrator (I have taken off the host name and replaced it with XXXX.com): +---------------------------------+-----------------------------------------+ | Variable_name | Value | +---------------------------------+-----------------------------------------+ | auto_increment_increment | 1 | | auto_increment_offset | 1 | | automatic_sp_privileges | ON | | back_log | 50 | | basedir | / | | binlog_cache_size | 32768 | | bulk_insert_buffer_size | 8388608 | | character_set_client | latin1 | | character_set_connection | latin1 | | character_set_database | latin1 | | character_set_filesystem | binary | | character_set_results | latin1 | | character_set_server | latin1 | | character_set_system | utf8 | | character_sets_dir | /usr/share/mysql/charsets/ | | collation_connection | latin1_swedish_ci | | collation_database | latin1_swedish_ci | | collation_server | latin1_swedish_ci | | completion_type | 0 | | concurrent_insert | 1 | | connect_timeout | 8 | | datadir | /var/lib/mysql/ | | date_format | %Y-%m-%d | | datetime_format | %Y-%m-%d %H:%i:%s | | default_week_format | 0 | | delay_key_write | ON | | delayed_insert_limit | 100 | | delayed_insert_timeout | 300 | | delayed_queue_size | 1000 | | div_precision_increment | 4 | | keep_files_on_create | OFF | | engine_condition_pushdown | OFF | | expire_logs_days | 0 | | flush | ON | | flush_time | 60 | | ft_boolean_syntax | + -><()~*:""&| | | ft_max_word_len | 84 | | ft_min_word_len | 4 | | ft_query_expansion_limit | 20 | | ft_stopword_file | (built-in) | | group_concat_max_len | 1024 | | have_archive | YES | | have_bdb | NO | | have_blackhole_engine | YES | | have_compress | YES | | have_crypt | YES | | have_csv | YES | | have_dynamic_loading | YES | | have_example_engine | YES | | have_federated_engine | YES | | have_geometry | YES | | have_innodb | YES | | have_isam | NO | | have_merge_engine | YES | | have_ndbcluster | DISABLED | | have_openssl | NO | | have_ssl | NO | | have_query_cache | YES | | have_raid | NO | | have_rtree_keys | YES | | have_symlink | YES | | hostname | XXXXXXX.com | | init_connect | | | init_file | | | init_slave | | | innodb_additional_mem_pool_size | 1048576 | | innodb_autoextend_increment | 8 | | innodb_buffer_pool_awe_mem_mb | 0 | | innodb_buffer_pool_size | 8388608 | | innodb_checksums | ON | | innodb_commit_concurrency | 0 | | innodb_concurrency_tickets | 500 | | innodb_data_file_path | ibdata1:10M:autoextend | | innodb_data_home_dir | | | innodb_adaptive_hash_index | ON | | innodb_doublewrite | ON | | innodb_fast_shutdown | 1 | | innodb_file_io_threads | 4 | | innodb_file_per_table | OFF | | innodb_flush_log_at_trx_commit | 1 | | innodb_flush_method | | | innodb_force_recovery | 0 | | innodb_lock_wait_timeout | 50 | | innodb_locks_unsafe_for_binlog | OFF | | innodb_log_arch_dir | | | innodb_log_archive | OFF | | innodb_log_buffer_size | 1048576 | | innodb_log_file_size | 5242880 | | innodb_log_files_in_group | 2 | | innodb_log_group_home_dir | ./ | | innodb_max_dirty_pages_pct | 90 | | innodb_max_purge_lag | 0 | | innodb_mirrored_log_groups | 1 | | innodb_open_files | 300 | | innodb_rollback_on_timeout | OFF | | innodb_support_xa | ON | | innodb_sync_spin_loops | 20 | | innodb_table_locks | ON | | innodb_thread_concurrency | 8 | | innodb_thread_sleep_delay | 10000 | | interactive_timeout | 45 | | join_buffer_size | 1048576 | | key_buffer_size | 536870912 | | key_cache_age_threshold | 300 | | key_cache_block_size | 1024 | | key_cache_division_limit | 100 | | language | /usr/share/mysql/english/ | | large_files_support | ON | | large_page_size | 0 | | large_pages | OFF | | lc_time_names | en_US | | license | GPL | | local_infile | ON | | locked_in_memory | OFF | | log | OFF | | log_bin | OFF | | log_bin_trust_function_creators | OFF | | log_error | | | log_queries_not_using_indexes | OFF | | log_slave_updates | OFF | | log_slow_queries | OFF | | log_warnings | 1 | | long_query_time | 10 | | low_priority_updates | OFF | | lower_case_file_system | OFF | | lower_case_table_names | 0 | | max_allowed_packet | 16777216 | | max_binlog_cache_size | 4294963200 | | max_binlog_size | 1073741824 | | max_connect_errors | 10 | | max_connections | 500 | | max_delayed_threads | 20 | | max_error_count | 64 | | max_heap_table_size | 16777216 | | max_insert_delayed_threads | 20 | | max_join_size | 18446744073709551615 | | max_length_for_sort_data | 1024 | | max_prepared_stmt_count | 16382 | | max_relay_log_size | 0 | | max_seeks_for_key | 4294967295 | | max_sort_length | 1024 | | max_sp_recursion_depth | 0 | | max_tmp_tables | 32 | | max_user_connections | 16 | | max_write_lock_count | 4294967295 | | multi_range_count | 256 | | myisam_data_pointer_size | 6 | | myisam_max_sort_file_size | 2146435072 | | myisam_recover_options | OFF | | myisam_repair_threads | 1 | | myisam_sort_buffer_size | 67108864 | | myisam_stats_method | nulls_unequal | | ndb_autoincrement_prefetch_sz | 1 | | ndb_force_send | ON | | ndb_use_exact_count | ON | | ndb_use_transactions | ON | | ndb_cache_check_time | 0 | | ndb_connectstring | | | net_buffer_length | 16384 | | net_read_timeout | 30 | | net_retry_count | 10 | | net_write_timeout | 60 | | new | OFF | | old_passwords | OFF | | open_files_limit | 4096 | | optimizer_prune_level | 1 | | optimizer_search_depth | 62 | | pid_file | /var/lib/mysql/XXXXXX.com.pid | | plugin_dir | | | port | 3306 | | preload_buffer_size | 32768 | | profiling | OFF | | profiling_history_size | 15 | | protocol_version | 10 | | query_alloc_block_size | 8192 | | query_cache_limit | 1048576 | | query_cache_min_res_unit | 4096 | | query_cache_size | 33554432 | | query_cache_type | ON | | query_cache_wlock_invalidate | OFF | | query_prealloc_size | 8192 | | range_alloc_block_size | 4096 | | read_buffer_size | 1048576 | | read_only | OFF | | read_rnd_buffer_size | 262144 | | relay_log | | | relay_log_index | | | relay_log_info_file | relay-log.info | | relay_log_purge | ON | | relay_log_space_limit | 0 | | rpl_recovery_rank | 0 | | secure_auth | OFF | | secure_file_priv | | | server_id | 0 | | skip_external_locking | ON | | skip_networking | OFF | | skip_show_database | OFF | | slave_compressed_protocol | OFF | | slave_load_tmpdir | /tmp/ | | slave_net_timeout | 3600 | | slave_skip_errors | OFF | | slave_transaction_retries | 10 | | slow_launch_time | 2 | | socket | /var/lib/mysql/mysql.sock | | sort_buffer_size | 1048576 | | sql_big_selects | ON | | sql_mode | | | sql_notes | ON | | sql_warnings | OFF | | ssl_ca | | | ssl_capath | | | ssl_cert | | | ssl_cipher | | | ssl_key | | | storage_engine | MyISAM | | sync_binlog | 0 | | sync_frm | ON | | system_time_zone | CDT | | table_cache | 1500 | | table_lock_wait_timeout | 50 | | table_type | MyISAM | | thread_cache_size | 128 | | thread_stack | 196608 | | time_format | %H:%i:%s | | time_zone | SYSTEM | | timed_mutexes | OFF | | tmp_table_size | 33554432 | | tmpdir | /tmp/ | | transaction_alloc_block_size | 8192 | | transaction_prealloc_size | 4096 | | tx_isolation | REPEATABLE-READ | | updatable_views_with_limit | YES | | version | 5.0.67-community | | version_comment | MySQL Community Edition (GPL) | | version_compile_machine | i686 | | version_compile_os | redhat-linux-gnu | | wait_timeout | 45 | +---------------------------------+-----------------------------------------+ 0 Quote Link to comment Share on other sites More sharing options...
avalony Posted March 16, 2009 Author Share Posted March 16, 2009 It seems like it is unable to generate invoice or any receipt. When I clicked on invoices and 'Mark Paid' the next screen is just blank (except for the header and sidebar). The same thing happens when I try to generate invoices. Any kind souls out there that can help me with this issue? Thank you in advance. 0 Quote Link to comment Share on other sites More sharing options...
VicToMeyeZR Posted March 16, 2009 Share Posted March 16, 2009 This sounds like the web server, not whmcs 0 Quote Link to comment Share on other sites More sharing options...
Polk Posted February 19, 2010 Share Posted February 19, 2010 No, this issue has to do with MYSQL STRICT Mode. 0 Quote Link to comment Share on other sites More sharing options...
