Display balance and invoices issue
Jortex
Im trying to display the clients balance and amount of invoices due in the client area, the code im using is:
Oustanding Balance: <a href="clientarea.php?action=invoices">{$stats.dueinvoicesbalance}</a>
And im adding it to the templates (default) header.tpl
The above works correctly on the clients home page but nowhere else (within WHMCS).
On other ages such as invoices, tickets etc.. it shows:
Oustanding Balance:
(i.e, it doesnt show the actual amount)
Any ideas?
Cheers.
Edit, just noticed its the same with - {$stats.numactivetickets}
Edited by Jortex
Thank you for the reply othello,
Ive searched all over the forum for examples on how to do what you suggested but no luck.
Is there somewhere i can see an example or at least what variables can be output by doing what you've said?
Cheers.
