StarD Posted February 2, 2009 Share Posted February 2, 2009 So when a customer creates a ticket its fine until they submit it then when it becomes /submitticket.php?step=3 The following shows up Forbidden You don't have permission to access submitticket.php on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. How would i fix this? Thanks, Don 0 Quote Link to comment Share on other sites More sharing options...
AndrewMKP Posted February 2, 2009 Share Posted February 2, 2009 Check that the permissions of the file submitticket.php are correct. 0 Quote Link to comment Share on other sites More sharing options...
StarD Posted February 2, 2009 Author Share Posted February 2, 2009 thanks that worked i changed the permission to 755 0 Quote Link to comment Share on other sites More sharing options...
StarD Posted February 3, 2009 Author Share Posted February 3, 2009 On a completely unrelated question I have this problem. During email piping I am asked to forward them to | php -q /home/username/public_html/billing/pipe/pipe.php but through cPanel i found out I can only get to |/home/username/hstevenr/public_html/billing/pipe/pipe.php How can I make this work? Also please note that when you enter something into cPanel the "home" folder is already there 0 Quote Link to comment Share on other sites More sharing options...
AndrewMKP Posted February 3, 2009 Share Posted February 3, 2009 It should generate the code in your Admin Area on what the email piping cron is. I suggest you also check out http://wiki.whmcs.com/Email_Piping more specifically http://wiki.whmcs.com/Email_Piping#Common_Problems 0 Quote Link to comment Share on other sites More sharing options...
