NickyThorne Posted January 6, 2009 Share Posted January 6, 2009 Hello, (Website URL - http://www.ouoma.com/order/cat/index.php) When you add a product to the cart, the cart page is blank. For example: When the user clicks the "Add to Cart" button, the url they are direced to is the default url to add that particular product to the card, which is: http://ouoma.com/order/cat/cart.php?a=add&pid=0000000003 But this page is blank, theres nothing on the page. Im assuming the card should be displayed with the product in there. Also i think it's worth mentioning that if you actually view the cart after attempting to add a product to the cart, it does actually appear there. Please tell me how i can sort this issue? Thanks in advance, Nicky Thorne. 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted January 6, 2009 Share Posted January 6, 2009 check to see if viewcart.tpl is either missing or corrupt 0 Quote Link to comment Share on other sites More sharing options...
