clothingsavers Posted October 9, 2008 Share Posted October 9, 2008 in admin > Configuration > General settings > (Ordeing) Tab  I have this Auto Redirect on Checkout option enabled:  Select to automatically redirect the user to the gateway      After I make a order and click on (Complete Order) button it automatically goes to the order confirmation page cart.php?a=complete with a link that says "Click here to go to your Client Area" ont he bottom.    I am using Quantum Gateway and I would really like it so that when a customer clicks on (Complete Order) it goes to where they type in the creditcard numbers to make the purchase.   Anyone know how to fix this? Its real urgent. 0 Quote Link to comment Share on other sites More sharing options...
redrat Posted October 9, 2008 Share Posted October 9, 2008 It is annoying that you made a second thread on this subject. Please open a ticket with Technical Support. 0 Quote Link to comment Share on other sites More sharing options...
clothingsavers Posted October 9, 2008 Author Share Posted October 9, 2008 It is annoying that you made a second thread on this subject. Please open a ticket with Technical Support. Â Already sent a support ticket and no answer. 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted October 9, 2008 Share Posted October 9, 2008 If you have customized your header.tpl to include a form you will have to edit the code/java in forwardpage.tpl eg.. I have 1 form in my header for domainchecker so in forwardpage.tpl I changed  document.forms[0].submit()todocument.forms[1].submit()so that it is redirected from the correct form 0 Quote Link to comment Share on other sites More sharing options...
