WHMCS & TCADMIN Need Help
Ka0sX
Ok i have got this far as you can see it says that i have created it but nothing happens on my dedicated server notyhing is even in pending auto setup
would any one have any ideas on what is wrong ? iam pretty sure i have everything wright in TCADMIN
any help would be greatfull
Server Command Success
Account Created Successfully
But nothing happens on my dedicated server i dropped back to WHMCS 3.6.1 as i was reading a few ppl said after that version tcadmin module dosnt work well i got this far but i cant see nothing happening on my server
any ideas ?
thanks in advance
  • 4 weeks later...
  • 2 months later...
It is not difficult, and it will support those games fine. It can be a bit confusing at first, but once you figure out TCAdmin, you will love it. Their forums are pretty active, and 99% of any questions/problems you may have have all ready been discussed :)
You will also find that many of us that use the 2 are active on both, I certainly know to myself and Victormyzr (spelling) that re active on both.
