Products on index page
inTeL
Adam, do you have alittle code that can pull the prices from whmcs database for a html page? I would like to pull my hosting prices. Thanks!
Hey,
You will need to use PHP to connect to the MySQL database and pull the specific products/services you require.
SELECT * FROM tblproducts;
The above SQL query would provide you all information (including price) for all products/services you offer.
I might create a script or post snippets if more people want this...
Thanks,
Adam
This should get you started. The database connection should already be open. It pulls the product pricing from the products table. Look at the tblproducts table in the database for other values.
Use {php}...{/php} tags around the code if you want to use it in a template file.
$query = 'SELECT * FROM tblproducts';
$result = mysql_query ($query);
while ($data = @mysql_fetch_array ($result))
$monthly = $data['monthly'];
$quarterly = $data['quarterly'];
$semiannual = $data['semiannual'];
$annual = $data['annual'];
$biennial = $data['biennial'];
$msetupfee = $data['msetupfee'];
$qsetupfee = $data['qsetupfee'];
$ssetupfee = $data['ssetupfee'];
$asetupfee = $data['asetupfee'];
$bsetupfee = $data['bsetupfee'];
if ($monthly == '0.00') {$monthly = 'FREE';} else {$monthly = $CONFIG['CurrencySymbol'].$monthly;}
if ($quarterly == '0.00') {$quarterly = 'FREE';} else {$quarterly = $CONFIG['CurrencySymbol'].$quarterly;}
if ($semiannual == '0.00') {$semiannual = 'FREE';} else {$semiannual = $CONFIG['CurrencySymbol'].$semiannual;}
if ($annual == '0.00') {$annual = 'FREE';} else {$annual = $CONFIG['CurrencySymbol'].$annual;}
if ($biennial == '0.00') {$biennial = 'FREE';} else {$biennial = $CONFIG['CurrencySymbol'].$biennial;}
if ($msetupfee == '0.00') {$msetupfee = 'FREE';} else {$msetupfee = $CONFIG['CurrencySymbol'].$msetupfee;}
if ($qsetupfee == '0.00') {$qsetupfee = 'FREE';} else {$qsetupfee = $CONFIG['CurrencySymbol'].$qsetupfee;}
if ($ssetupfee == '0.00') {$ssetupfee = 'FREE';} else {$ssetupfee = $CONFIG['CurrencySymbol'].$ssetupfee;}
if ($asetupfee == '0.00') {$asetupfee = 'FREE';} else {$asetupfee = $CONFIG['CurrencySymbol'].$asetupfee;}
if ($bsetupfee == '0.00') {$bsetupfee = 'FREE';} else {$bsetupfee = $CONFIG['CurrencySymbol'].$bsetupfee;}
If you have problems I am available for hire.
Ok, so far so good but I have a question.
How do I can the code to display items like this:
Plan 1 | Plan 2 | Plan 3 | Plan 4
Disk space <<>> Disk space <<>> Disk space <<>> Disk space
Bandwidth <<>> Bandwidth <<>> Bandwidth <<>> Bandwidth
Price <<>> Price <<>> Price <<>> Price
Retrieving the Disk Space, Bandwidth and Price for each plan. Thanks!
Thanks Adam I got the prices to show but I would like some of the other fields to show also using configoption1, configoption2 etc fields, I just don't know how to do it.
This is what I used to get the prices but I created a file for each package:
  if ($package == '1')  echo ("$monthly") ;
This is what I have used in my site on my hosting.php page
Put it in your custom php file and then in the template that your php file is calling use for example
{$plan2_WebSpaceQuota}
To get all the variables assigned put {debug} in your template page somewhere.
$id = $data['id'];
assign('plan'.$id , $data['name']);
$smartyvalues['plan'.$id.'_description'] = $data['description'];
$smartyvalues['plan'.$id.'_hidden'] = $data['hidden'];
$smartyvalues['plan'.$id.'_stockcontrol'] = $data['stockcontrol'];
$smartyvalues['plan'.$id.'_qty'] = $data['qty'];
$smartyvalues['plan'.$id.'_paytype'] = $data['paytype'];
$smartyvalues['plan'.$id.'_subdomain'] = $data['subdomain'];
$smartyvalues['plan'.$id.'_defaultserver'] = $data['defaultserver'];
$smartyvalues['plan'.$id.'_freedomain'] = $data['freedomain'];
$smartyvalues['plan'.$id.'_freedomainpaymentterms'] = $data['freedomainpaymentterms'];
$smartyvalues['plan'.$id.'_freedomaintlds'] = $data['freedomaintlds'];
if ($data['servertype'] == 'cpanel')
$smartyvalues['plan'.$id.'_Pack'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_FTP'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_WebSpaceQuota'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_Email'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_BandwidthLimit'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_DedicatedIP'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_Shell'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_SQL'] = $data['configoption8'];
$smartyvalues['plan'.$id.'_CGI'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_Subdomains'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_Frontpage'] = $data['configoption11'];
$smartyvalues['plan'.$id.'_MaxParkedDomains'] = $data['configoption12'];
$smartyvalues['plan'.$id.'_cPanelTheme'] = $data['configoption13'];
$smartyvalues['plan'.$id.'_AddonDomains'] = $data['configoption14'];
$smartyvalues['plan'.$id.'_LimitResellerbyNumber'] = $data['configoption15'];
$smartyvalues['plan'.$id.'_LimitResellerbyUsage'] = $data['configoption16'];
$smartyvalues['plan'.$id.'_DiskSpace'] = $data['configoption17'];
$smartyvalues['plan'.$id.'_Bandwidth'] = $data['configoption18'];
$smartyvalues['plan'.$id.'_AllowDSOverselling'] = $data['configoption19'];
$smartyvalues['plan'.$id.'_AllowBWOverselling'] = $data['configoption20'];
$smartyvalues['plan'.$id.'_ResellerACLList'] = $data['configoption21'];
if ($data['servertype'] == 'hypervm')
$smartyvalues['plan'.$id.'_Type'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_PlanName'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_OSTemplate'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_Server'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_NumberOfIPs'] = $data['configoption5'];
if ($data['servertype'] == 'dotnetpanel')
$smartyvalues['plan'.$id.'_PackageName'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_WebSpaceQuota'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_BandwidthLimit'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_PlanID'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_ParentSpaceId'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_EnterpriseServerPort'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_DifferentPotalURL'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_PortalURL'] = $data['configoption8'];
$smartyvalues['plan'.$id.'_SendDNPAccountSummaryemail'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_SendDNPHostingSpaceSummaryemail'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_CreateMailaccount'] = $data['configoption11'];
$smartyvalues['plan'.$id.'_CreateFTPaccount'] = $data['configoption12'];
$smartyvalues['plan'.$id.'_Temporarydomain'] = $data['configoption13'];
$smartyvalues['plan'.$id.'_HTMLemail'] = $data['configoption14'];
$smartyvalues['plan'.$id.'_CreateWebsite'] = $data['configoption15'];
if ($data['servertype'] == 'enomssl')
$smartyvalues['plan'.$id.'_CertificateType'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_Years'] = $data['configoption4'];
if ($data['servertype'] == 'tcadmin')
$smartyvalues['plan'.$id.'_GameID'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_GameSlots'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_GamePrivate'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_GameAdditionalSlots'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_GameIsBranded'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_AdditionalArguments'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_VoiceID'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_VoiceSlots'] = $data['configoption8'];
$smartyvalues['plan'.$id.'_VoicePrivate'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_VoiceAdditionalSlots'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_GameDatacenter'] = $data['configoption11'];
if ($data['servertype'] == 'whmsonic')
$smartyvalues['plan'.$id.'_OS'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_DonotsetupradiogiveaccessviacPanel'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_MaxListenerLimit'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_UseFreePort'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_ServerIP'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_UsersWHMSonicAccessviacPanel'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_MaxBitRate'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_AutoDJFeature'] = $data['configoption8'];
$smartyvalues['plan'.$id.'_WHMPackageName'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_BitRateAbuse'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_BandwidthLimit'] = $data['configoption11'];
if ($data['servertype'] == 'centovacast')
$smartyvalues['plan'.$id.'_URLtoCentovaCast'] = $data['configoption1'];
$smartyvalues['plan'.$id.'_Maxlisteners'] = $data['configoption2'];
$smartyvalues['plan'.$id.'_Maxbitrate'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_Datatransferlimit'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_Diskquota'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_Server-sidesource'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_Startserver'] = $data['configoption7'];
if ($data['servertype'] == 'scpanel')
$smartyvalues['plan'.$id.'_OS'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_MaxUsers'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_NextPort'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_MaxTraffic'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_TrafficAbuse'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_MaxBitRate'] = $data['configoption8'];
$smartyvalues['plan'.$id.'_BitRateAbuse'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_OnDemand'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_Proxy'] = $data['configoption11'];
$smartyvalues['plan'.$id.'_WHMPackageName'] = $data['configoption12'];
$smartyvalues['plan'.$id.'_IntroBackupMaxSize'] = $data['configoption13'];
$smartyvalues['plan'.$id.'_OnDemandMaxSize'] = $data['configoption14'];
$smartyvalues['plan'.$id.'_UsePortPrefixDomain'] = $data['configoption15'];
if ($data['servertype'] == 'castcontrol')
$smartyvalues['plan'.$id.'_Auth'] = $data['configoption3'];
$smartyvalues['plan'.$id.'_Host'] = $data['configoption4'];
$smartyvalues['plan'.$id.'_Path'] = $data['configoption5'];
$smartyvalues['plan'.$id.'_Port'] = $data['configoption6'];
$smartyvalues['plan'.$id.'_MaxUsers'] = $data['configoption7'];
$smartyvalues['plan'.$id.'_Bandwidth'] = $data['configoption9'];
$smartyvalues['plan'.$id.'_AutoDJ'] = $data['configoption10'];
$smartyvalues['plan'.$id.'_AutoDJQuota'] = $data['configoption11'];
$smartyvalues['plan'.$id.'_SystemID'] = $data['configoption12'];
$smartyvalues['plan'.$id.'_monthly'] = $monthly;
$smartyvalues['plan'.$id.'_quarterly'] = $quarterly;
$smartyvalues['plan'.$id.'_semiannual'] = $semiannual;
$smartyvalues['plan'.$id.'_annual'] = $annual;
$smartyvalues['plan'.$id.'_biennial'] = $biennial;
$smartyvalues['plan'.$id.'_msetupfee'] = $msetupfee;
$smartyvalues['plan'.$id.'_qsetupfee'] = $qsetupfee;
$smartyvalues['plan'.$id.'_ssetupfee'] = $ssetupfee;
$smartyvalues['plan'.$id.'_asetupfee'] = $asetupfee;
$smartyvalues['plan'.$id.'_bsetupfee'] = $bsetupfee;
You can use the hidden variable to not display that section. Example snip of my template file
{if !$plan2_hidden}
<div class="fleft aligncenter" style="width:81px;">
{$plan2_AddonDomains}<br />
{$plan2_MaxParkedDomains}<br />
{$plan2_WebSpaceQuota} MB<br />
{$plan2_BandwidthLimit} MB<br />
{$plan2_Email}<br />
{$plan2_SQL}<br />
{$plan2_FTP}<br />
<a href="cart.php?a=add&pid=2"><img alt="" src="templates/{$template}/images/order_but1.gif" /></a>
</div>
{/if}
I normally charge for this sort of extreme but I must be in a good mood today.
(however donations gracefully accepted via paypal to [billing at tshosting.com.au])
Hey,
Since the SQL statement calls for everything in the DB (*) all the fields listed in tblproducts can be called.
echo $data['monthly'];
echo $data['id'];
echo $data['configoption1'];
Than you do something like
if($data['gid'] == 1 && $data['hidden'] != "on" )
   echo $data['name'];
   echo "<br />";
   echo $data['description'];
   echo "<br />";
   echo $data['qty'];
Thanks,
Adam
advanced.php content
<?php
   $package = $data['id'];
I did this for all the other plans by just changing the package number
if ($package == '[color=red][b]1[/b][/color]')  echo ("$monthly") ;
and renaming the advanced.php to say standard.php
And I included this file into my html file.
This works but to add the the different configoptions1,2,3 etc to the same html is where I'm stumped. And your code seems as if I have to put it in a tpl file am I wrong? Thanks!
