how to display radio selection than checkbox in configureproduct.tpl
stevenrca
Hi Friends,
Wanted to know if their is any way to display radio selection than checkbox in product addons tpl file [configureproduct.tpl].
Below is whats the exisitng code.
{/if} {if $addons} {$LANG.cartaddons}
{$LANG.orderaddondescription}
{foreach key=num item=addon from=$addons} {$addon.checkbox}
{$addon.name} - {$addon.description}
{/foreach}
{/if} {if $customfields} {$LANG.orderadditionalrequiredinfo}
{$LANG.cartcustomfieldsdesc}
Hi Steve Bros,
My intention is to allow only 1 addon in the selection. Thats why asked if any one can help me out. Following is the latest code - giving some error once selected - anyone can help me out here please.
<table>
<tr>
<td><input type="radio" name="addon.id" value="addons" id="addon.id" onclick="document.getElementById('addon').style.display='none'" /></td>
<td><label for="a{$addon.id}"><strong>{$addon.name}</strong> - {$addon.description} </label></td>
</tr>
{/foreach}
</table>
hi,
Was able to get few things done ... but still not able to pass the values to next page. The below display radio selection or the list.
<table>
<tr>
<td><input type="radio" name="radioaddon" value="addon" id="addon.id"/></td>
</tr>
{/foreach}
</table>
<select name="addon">
<option value="a{$addon.id}"><strong>{$addon.name}</strong> - {$addon.description}</option>
{/foreach}
</select>
Apriciate if some one can help me out on this. :?
Howdy,
I got this working fine with no issues.
{foreach key=num item=configoption from=$configurableoptions}
<tr class="orderrow{if $num % 2}2{else}1{/if}">
<td>{$configoption.optionname}</td>
<td>
{foreach key=num2 item=options from=$configoption.options}
	<input type="radio" name="configoption[{$configoption.id}]" value="{$options.id}"{if $configoption.selectedvalue eq $options.id} checked{/if}>{$options.name} <br />
{/foreach}
</td>
</tr>
{/foreach}
Online Example:
https://hq.solidnetdc.com/orders/order.php?step=2&pid=165&systemtemplate=portal
FYI: I am running an older version of WHMCS and do not know if the same syntax is still used for newer versions.
Thanks,
Adam
Can someone pls explain how to parse the value from the addons to the next page from a SELECT dropdown menu.
{/foreach}
</select>
{/foreach}
</select>
Howdy,
Can you explain to us what you are trying to do? Create a dropdown box, or what? I do not understand what your question.
Thanks,
Adam
{/foreach}
</select>
Try this... not 100% sure but it should work
<select name="addon" onchange="submit()">
{/foreach}
</select>
