Help!! [down for maintenance]
Turbocom
Alright sorry if this isn't in the correct forum but I need help :S I switched hosts and I did not re-install WHMCS on my new host just transfered the files and now I get this:
Down for Maintenance
An upgrade is currently in progress... Please come back soon...
WHAT DO I DO?
WHAT DO I DO?
LOL, might seem like a dumb question, but did you transfer the database se well and made sure the configuration.php file was updated with the correct db settings?
  • Retired Forum Member
Hi
This means that some files may be missing or not updated and do not match the database. You will need to re upload all your WHMCS directory files again. Do not overwrite the configurations.php file and do not upload the install folder. Some of your files may not have uploaded or been overwritten in your upgrade/install.
Joe
