sboselli Posted August 5, 2008 Share Posted August 5, 2008 I need to execute a shell script to create some custom users and files after an order´s been paid through Paypal. I use the Single page templates. From what i´ve found in searches i would need to use checkoutscript.php, but in the setup i got from my VPS there is no includes/checkoutscript.php or anywhere else either... If so, how would i go about doing it? Thanks, Santiago. 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted August 14, 2008 Share Posted August 14, 2008 Hi If you are using cPanel/WHM and have root access just create a new script on your server /scripts/postwwwacct or /scripts/postwwwacctuser More info on the cPanel.net website 0 Quote Link to comment Share on other sites More sharing options...
Zorro67 Posted August 14, 2008 Share Posted August 14, 2008 Any suggestions if you don't use/ don't have shell access in cPanle? 0 Quote Link to comment Share on other sites More sharing options...
sparky Posted August 15, 2008 Share Posted August 15, 2008 You could also use the action hooks in WHMCS Add your code to the actionhook_AfterModuleCreate function in /includes/actionhooks.php file All hooks available are: # This function runs when the user checks out using the shopping cart actionhook_ShoppingCartCheckout # This function runs when a new client is added actionhook_ClientSignup # This function runs when a change is made to clients details - name, address, email, password, etc... actionhook_ClientDetailsEdit # This function runs when a client logs in actionhook_ClientLogin # This function runs when a client logs out actionhook_ClientLogout # This function runs when a client is deleted actionhook_ClientDelete # This function runs when an invoice is fully paid and therefore the services renewed actionhook_InvoicePaid # This function runs when a ticket is opened actionhook_TicketOpen # This function runs when a ticket is replies to by a client or admin user actionhook_TicketReply # This function runs when a module creation command completes successfully - various variables available actionhook_AfterModuleCreate # This function runs when a module suspension command completes successfully - various variables available actionhook_AfterModuleSuspend # This function runs when a module unsuspension command completes successfully - various variables available actionhook_AfterModuleUnsuspend # This function runs when a module terminate command completes successfully - various variables available actionhook_AfterModuleTerminate # This function runs prior to checkout processing to allow for manipulation of cart session data actionhook_PreShoppingCartCheckout Hope that helps 0 Quote Link to comment Share on other sites More sharing options...
Zorro67 Posted August 15, 2008 Share Posted August 15, 2008 thanks Steve. 0 Quote Link to comment Share on other sites More sharing options...
dan.trainor Posted April 9, 2009 Share Posted April 9, 2009 Hi - Zorro, did you ever get this working? For the life of me, I'm having trouble making these action hooks actually do anything - specifically: actionhook_AfterModuleCreate actionhook_AfterModuleSuspend actionhook_AfterModuleUnsuspend actionhook_AfterModuleTerminate I've written really big elaborate code and functions, to simply doing a print_r($data), to exec()'ing a touch on some file in /tmp - I just can't get them to execute. Anyone have any tips on this? Had any problems in the past? If so, what did you do about it? Thanks! -dant 0 Quote Link to comment Share on other sites More sharing options...
