Help with portal template Please
mrsandre
everything was working fine but....for some reason all the text and logins are off.
The text is bunched together and you really can't see where to input the password.
the other issue is all the bold text is gone and everything is centered.
Heya
You have a Table with the class 'wrapper' as your main wrapping element. The centering issue is with this table:
<table cellspacing="0" cellpadding="0" align="center" class="wrapper">
Notice align="center" -- This is the cause for your centered text. Removing that will resolve. Probably a good idea to add a style="text-align: left;"
Most all of your other issues are related to your use of the WildCard Zeroing of all margins/padding, etc. Here is your CSS on line 1:
* {style.css (line 1)
-x-system-font:none;
border:0pt none #000000;
font-family:Arial,sans-serif;
font-size:12px;
font-size-adjust:none;
font-stretch:normal;
font-style:normal;
font-variant:normal;
font-weight:normal;
line-height:12px;
margin:0pt auto;
padding:0pt;
text-align:center;}
Zeroing "everything" should be followed up with some general spacing to some elements. Personally, I don't use wildcards. I setup each element so they're predictable. This has the same effect of using the wildcard (making things consistent across all browsers), but takes longer. Less headaches though.
If you still want to use the wildcard, it looks like its having the most drastic effect on your tablecells (td) and paragraph (p) elements. Setup some margins/padding where appropriate for those and you should be a little better off. Also note your wildcard (*) is applying another text-centering to things.
Hope that helps ya some.
