Nominet Help Again.
DaveHarris
I know this keeps poping up but i'm having great problems with the nominet module.
I have been through all the suggestions in the group but i'm still having issues with emails unsigned.
I think it is something to do with either the path to gpg , someone suggested this needed changing in the php environment settings?? Or the user apache runs as in my case nobody
Any assistance with this would be helpful.
for instance what path should be in the module for "Path to the PGP config and keyring (if apache uid is nobody)"
How can I test the command line for user Nobody ? It works fine from root and the user that runs whmcs?
Failing this anyone want to take this on as a commercial fix?
Dave
*if* whmcs is running as a user (you're using plesk or suPHP?) then you dont need the path to a home directory for nobody, as the call wont be made by nobody :D
make sure n the gpg conf you have set the default key to use
