casa Posted June 14, 2008 Share Posted June 14, 2008 Hi, I am a braziliam and here in Brazil we have many extensions (TLD`s) for domains. And I have a customer that use a .nom.br (customer.name.nom.br) eg. john.barry.nom.br The system is not accept this one. I check the file whoisservers.php in include folder and the extension is there (.nom.br|whois.nic.br|No match for) Please, how can I solve it? Thank you. 0 Quote Link to comment Share on other sites More sharing options...
casa Posted June 15, 2008 Author Share Posted June 15, 2008 Any braziliam can help me? Thank you. 0 Quote Link to comment Share on other sites More sharing options...
WHI Posted June 16, 2008 Share Posted June 16, 2008 Hello, I have this problem too. I'm form hungary. What should I do? Could you help me anybody? Thanks 0 Quote Link to comment Share on other sites More sharing options...
casa Posted June 16, 2008 Author Share Posted June 16, 2008 The support told me this problem is because the "." between the names and the whmcs not support this caracter, like john.barry.nom.br (is not possible). 0 Quote Link to comment Share on other sites More sharing options...
bluenova Posted June 17, 2008 Share Posted June 17, 2008 I don't think that is the issue because I use: .co.uk .me.uk .org.uk which all work fine, but they have to be setup like that in the domain pricing screen as 3 options. i.e. I do not have a .uk option. 0 Quote Link to comment Share on other sites More sharing options...
casa Posted June 17, 2008 Author Share Posted June 17, 2008 The problem is not in the .nom.br (it`s ok). The problem is eg. john.barry eg. john.barry.nom.br (not work) 0 Quote Link to comment Share on other sites More sharing options...
pacwebhosting Posted June 17, 2008 Share Posted June 17, 2008 Hi, Is it not because in your example john is a subdomain of barry.nom.br ? so you could register barry.nom.br and then add john as a subdomain in cpanel or whatever you use? ie you can not have john.barry.nom.br without first registering barry.nom.br Which unless I am missing something is how it is meant to work? If that makes sense? Thanks Paul **EDIT I now see your problem! after reading up on .nom.br - maybe WHMCS could code you a module for it? 0 Quote Link to comment Share on other sites More sharing options...
casa Posted June 17, 2008 Author Share Posted June 17, 2008 No, john is not a subdomain. The nom.br is a special TLD and it`s require 2 names for register. If you try register barry.nom.br the Registrar don`t accept. 0 Quote Link to comment Share on other sites More sharing options...
pacwebhosting Posted June 17, 2008 Share Posted June 17, 2008 **EDIT I now see your problem! after reading up on .nom.br - maybe WHMCS could code you a module for it? Hi Yes, I had already edited my post after reading up! WHMCS may be able to do you a custom registrar module for this type of domain for a cost, worth asking them Thanks Paul 0 Quote Link to comment Share on other sites More sharing options...
dmc Posted February 8, 2012 Share Posted February 8, 2012 Hi! Hello, I have this problem too. I'm form hungary. What should I do? Could you help me anybody? What you need to work tute? 0 Quote Link to comment Share on other sites More sharing options...
