lcorbett Posted May 7, 2008 Share Posted May 7, 2008 I am setting up a small website design and hosting company (and also ofering domain registration under eNom). In WHM, I set up my hosting Packages. I named each package, for instance, Plan A. WHM saved this Package with my login name attached "MyName_Plan A". OK, so now I go to WHMCS and I've created my suite of products and given it the Group Name "Web Hosting Packages" Then create a new Product/Service. Do I give the product the exact name "MyName_Plan A"? Next question: In product type, do I list it under "Shared Hosting Account" or "Other"? Or does it matter? I set up storage space limits, bandwidth, number of email accou nts, etc. in the WHM control panel, do I need to re-enter all of that again in WHMCS? Or will it automatically integrate itself? Last question for now... How do I test to see if the order process works the way it should? Thanks in advance...I spent time reading the knowledge base, the online documentation, and did a search in this forum for some other questions I had, and got most answers I needed. But I'm sure I'll be back for more... Please bear with me Oh wait...one more question...grin... I set up my servers in WHMCS ns1.mycompany.biz ns2.mycompany.biz When I set up my new products, in the Default Install Server, I'm given a choice of "Use System Default" or "MyCompany". I'm assuming I want "MyCompany" 0 Quote Link to comment Share on other sites More sharing options...
mylove4life Posted May 7, 2008 Share Posted May 7, 2008 http://wiki.whmcs.com/Products_and_Services Will get you started.. 0 Quote Link to comment Share on other sites More sharing options...
lcorbett Posted May 8, 2008 Author Share Posted May 8, 2008 Thank you....that did get me started, but it didn't answer my questions... 1. Does the Package Name from WHM and the Product Name in WHMCS need to match exactly? i.e. WHM added my username to my Package name. I set up the Package as "Plan A". WHM saved it as "MyName_Plan A". So in the New Products/Services in WHMCS, do I call the new product "MyName_Plan A", or call I call it "Plan A"? 2. These are hosting plans. So, in WHMCS, do I set these up under the "Shared Hosting" or "Other" option in the Product Group? Or does it matter? 3. If WHMCS is integrated with WHM, why do I need to fill in all the same info for setting up a new Product, and why am I seeing Reseller options in the Product setup? I'm clueless, am I missing something obvious? Thanks again 0 Quote Link to comment Share on other sites More sharing options...
chickendippers Posted May 8, 2008 Share Posted May 8, 2008 1. Yes, package name must match exactly 2. If they're shared hosting plans, then select Shared Hosting 3.You don't need to fill in all the fields. 0 Quote Link to comment Share on other sites More sharing options...
lcorbett Posted May 8, 2008 Author Share Posted May 8, 2008 Thank you to both...I think I've got it now... 0 Quote Link to comment Share on other sites More sharing options...
