Stealthusa Posted September 4, 2006 Share Posted September 4, 2006 ok i am not sure if this is a bug or what but i set up another site and when i got the email with the info this is how it shows. Temporarily you may use one of the addresses given below manage your web site Temporary FTP Hostname: whmcs.com Temporary Webpage URL: http://xx.xxx.xx.xxx/~myimage/ Temporary Control Panel: http://xx.xxx.xx.xxx/cpanel Once your domain has Propagated FTP Hostname: xxx.xxxxxxx.com Webpage URL: http://xxx.xxxxxxx.com Control Panel: http://xxx.xxxxxxx.com/cpanel if you look you will see the temporay webpage url is showing a ~ which shouldn't show that it not putting the right link in for a client. and on the next line you see just the ip no. and the /cpanel that is not the right link for that and same on the next lines if you look at them hope someone can help me on this. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted September 4, 2006 WHMCS CEO Share Posted September 4, 2006 Hi, The temporary url should have a ~ unless you are running a different server to cPanel. Any modifications you want doing to th emails should just be done in Configuration > Email Templates - you can modify them to be however you like. Matt 0 Quote Link to comment Share on other sites More sharing options...
Stealthusa Posted September 4, 2006 Author Share Posted September 4, 2006 well what i want is that so when a client gets there email with the info on it all they have to do is click the link in there mail and it takes them righ to the link 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted September 5, 2006 WHMCS CEO Share Posted September 5, 2006 For most hosts the default email templates work perfectly fine. If you have an unusual setup then you will need to edit the templates so they are as you require. Matt 0 Quote Link to comment Share on other sites More sharing options...
Stealthusa Posted September 5, 2006 Author Share Posted September 5, 2006 i sent in a ticket on how it looks when you hoover your mouse over the link this is what it shows. Temporary Control Panel: http://xx.xxx.xx.xxx/cpanel is how it looks but when hoover over it or click it it wants to give you a link like this http://[serverip]/cpanel 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted September 5, 2006 WHMCS CEO Share Posted September 5, 2006 I assumed the x's are somethign you are putting in just when posting on the forum to hide your real IP address? Are you trying to say it is putting xx.xxx.xx.xxx instead of your servers ip? Matt 0 Quote Link to comment Share on other sites More sharing options...
Stealthusa Posted September 5, 2006 Author Share Posted September 5, 2006 no that is just to hide the ip address it puts the ip there the right one it shows it but as for the link when you hoover or it or like it it trys to send you to this link instead http://[serverip]/cpanel that is the link it has behind the ip it gives 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted September 5, 2006 WHMCS CEO Share Posted September 5, 2006 Ok, as I've said earlier in the topic, go to Configuration > Email Templates, edit the Hosting Account Welcome Email template, click the View Source button on the editor menu bar (hover over each icon for its description). Then locate the link and enter [serverIP] in place of [serverip]. This was an error in the BETA and was fixed for the main release. Matt 0 Quote Link to comment Share on other sites More sharing options...
Stealthusa Posted September 5, 2006 Author Share Posted September 5, 2006 ok will do that not sure why i have it then because this is the newer version which was a fresh install 0 Quote Link to comment Share on other sites More sharing options...
thehostinghut Posted October 30, 2006 Share Posted October 30, 2006 Ok, as I've said earlier in the topic, go to Configuration > Email Templates, edit the Hosting Account Welcome Email template, click the View Source button on the editor menu bar (hover over each icon for its description). Then locate the link and enter [serverIP] in place of [serverip]. This was an error in the BETA and was fixed for the main release. Matt I think this is still a problem. When I created a new email template and used [Domain] and sent myself a test email with it it done what just what Stealthusa said. When I changed the source as you said it fix the problem. Will this get fixed? 0 Quote Link to comment Share on other sites More sharing options...
thehostinghut Posted October 30, 2006 Share Posted October 30, 2006 This only seems to be when the email template is not set to the default for the Welcome email in the Product. If I set the new email template as the default it does not happen. Is there something I can change to make this go away? Thanks, Tracy 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted October 31, 2006 WHMCS CEO Share Posted October 31, 2006 The fact it gets changed is caused by the rich text editor. This is developed by a third party so it changing the characters is not something I can fix. This is why in 2.5.8, there is an option to switch between the editor and plain HTML so you can just check none of the tags have been modified for their HTML character code equivalent. Matt 0 Quote Link to comment Share on other sites More sharing options...
MACscr Posted October 31, 2006 Share Posted October 31, 2006 The fact it gets changed is caused by the rich text editor. This is developed by a third party so it changing the characters is not something I can fix. This is why in 2.5.8, there is an option to switch between the editor and plain HTML so you can just check none of the tags have been modified for their HTML character code equivalent. Matt Would be nice if it could be turned off by default in the admin area. That way it would be a little more mobile friendly. 0 Quote Link to comment Share on other sites More sharing options...
thehostinghut Posted October 31, 2006 Share Posted October 31, 2006 The fact it gets changed is caused by the rich text editor. This is developed by a third party so it changing the characters is not something I can fix. This is why in 2.5.8, there is an option to switch between the editor and plain HTML so you can just check none of the tags have been modified for their HTML character code equivalent. Matt Why does it work when I make it the deafult template for a package but not work when it is not set to default? Then I have to go make the html changes. That is what is strange to me. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS CEO Matt Posted October 31, 2006 WHMCS CEO Share Posted October 31, 2006 No, that would not have any effect. Whether you have it the default welcome email for a package or not makes no difference. Matt 0 Quote Link to comment Share on other sites More sharing options...
thehostinghut Posted October 31, 2006 Share Posted October 31, 2006 No, that would not have any effect. Whether you have it the default welcome email for a package or not makes no difference. Matt It does though I guess that is my point. When I made my first email template I sent myself a test message and the links just had the http://[domain].com and so on. Then I just changed it to the default for that package and sent the email again and it came through just fine. So I set the emails back to what they were and made the html changes and it worked without setting it to default. I will make another one and forward you the two emails if you like. Tracy 0 Quote Link to comment Share on other sites More sharing options...
thehostinghut Posted October 31, 2006 Share Posted October 31, 2006 Forget it 0 Quote Link to comment Share on other sites More sharing options...
