Problem with HTML tags in knowledgebase articles.
Zorro67
Hi guys.
This is for all those people that may have had a similar problem to myself with HTML tags not representing properly in your KB.
Matt kindly provided an easy solution, sO I thought it appropriate to post that here.
I recently upgrade from v3.5.1 to v3.6.0 (successfully)
my KB articles looked fine before the upgrade.
Now when adding a new KB article (or if editing an old KB), the html tags & formatting marks show in the article instead of the fully formatted text
Eg."<p>To send mails from your@domain.com.au to gmail, </p><ol><li>Login to our cPanel hosting account</li><li>In the 'Mail' section, select the 'Forwarders' icon.</li><li>Create a new email forwarder from yourname@domain.com.au to yourname@gmail.com.</li><li>" etc etc.
Is there a config item that i need to set after the upgrade? (If so I obviously missed it).
Following from that, is there a setting to set the number of displayed characters previewed on a KB "most popular"?
I have posted Matt's resposnse and attachment in the following file
And the winner is ............
Hi Daniel,
I am attaching a file that will correct this issue - just upload this to your admin folder and then resave the articles. Regarding the number of characters to show, you can customise that in the template file knowledgebase.tpl I believe.
Regards,
Matt
End of quote.
BTW. If the file didn't attach, please request from Matt.
"Here endeth the Lesson"
