Modules not showing after installation
Hi Jackson
First, make sure you’ve completed all prerequisites:
  • Correct PHP version installed
  • Composer available (if required)
  • Proper write permissions on /modules or installation directory
  • Clean cache after installation
A lot of “missing modules” issues come from the cache not refreshing after install.
On 5/21/2026 at 7:13 PM, Jackson12 said:
I’m trying to install ModulesStack from
https://modulesstack.com/installation/
I followed the steps, but I’m not sure if I’m doing it correctly. The installer runs, but the modules don’t appear in my admin panel. Has anyone successfully installed it? What am I missing?
One common issue is running the installer but not finalizing the module registration step.
After installation:
  • Check if modules were actually copied into the correct directory
  • Refresh the admin panel fully (hard reload)
  • Rebuild the module index if your system supports it
Sometimes the UI shows success, but the modules are not registered in the system database yet.
