problem betwin Centova cast and whmc please help
avilsrv
hi,
i have Centova cast (radio panel) and whms fully integrated and working .
but there is a problem :
whan i am opening radio in Centova cast it open it for me normaly ,
on port 8000 8002 8004 etc ...,it jamps 2 ports for every radio.
but whan i am doing it throgh the whmc buying prosses it sucssesfuly manage to open a radio/radios but on ports like 8000 8001 8002 8003 etc.. it is not jumping 2 ports for every radio.(every radio need 2 ports to work proparly)
what can i do ,or is there someone familiar with this issue ?
tnx in advance .
I am having the same problem.
Shoutcast works on 2 ports:
1- The shoutcast listener port (main port)
2- The source port (which is by default the next consecutive port from the main port)
Centovacast is not skipping ports.
I think this is not a WHMCS issue. I thinks it's a Centova API issue, becuase Centova is doing the same thing.
Anyone ?
  • 1 month later...
