Setting up Nominet Module
Rob K
Hi
I am about to setup the Nominet module and was wondering if anyone can give any advice on the best way to do it.
I am running it on a Windows server and have a TAG with Nominet, I have also setup my passphrase.
What PGP software do you use and what do you put in the PGPHome box?
Thanks
Im in the same position, have nominet TAG, have been using Windows basec app till now.
My server that hosts WHMCS is Unix based.
If anyone can provide some guidance on setting up the PGP keys on the server it would be a great help.
Rob,
The software I currently use on my desktop is: http://www.pgp.com/products/desktop_email/index.html
Not sure if this can be run on a wondows hosting server...
Flaming
