problem when configuressl.php
AladdinJ
  • WHMCS Technical Analyst
If you are still experiencing this issue, can I ask, are you using a custom / third-party template?  If so, could you try to see if you can reproduce the issue using our stock default Twenty-One system template, and Standard Cart order form template.
For further information, visit
https://help.whmcs.com/m/customisation/l/680993-changing-the-system-template
https://help.whmcs.com/m/order_forms/l/678181-change-your-order-form-template
If for some reason, the issue continues, please open a ticket with our technical support team, where we will be glad to look into this for you.
