GhostRider Posted October 21, 2021 Share Posted October 21, 2021 (edited) Hello there, I've installed the most recent whmcs 8.3.0 on localhost, which is running DesktopServer. During installation, there were no problems. I followed the wizard's advice and deleted the install folder. The front page is loading properly. attempted to log in to the backend The form is loaded, but when I try to login, I get the following error (I activated the $display errors setting in configuration.php).: Oops! Something went wrong and we couldn't process your request. Please go back to the previous page and try again. For additional assistance, please reference the WHMCS TroubleShooting Guide » TypeError: Return value of WHMCS\Support\TicketMask::gatherMaskPossibilities() must be of the type int, float returned in C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Support\TicketMask.php:0 Stack trace: #0 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\View\Admin\HealthCheck\HealthCheckRepository.php(0): WHMCS\Support\TicketMask->gatherMaskPossibilities() #1 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\View\Admin\HealthCheck\HealthCheckRepository.php(0): WHMCS\View\Admin\HealthCheck\HealthCheckRepository->checkTicketMask() #2 C:\whmcsdev.test\includes\api\gethealthstatus.php(0): WHMCS\View\Admin\HealthCheck\HealthCheckRepository->nonKeyChecks() #3 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Api\V1\Api.php(0): unknown() #4 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Api\V1\Api.php(0): WHMCS\Api\V1\Api->executeApiCall() #5 C:\whmcsdev.test\includes\functions.php(0): WHMCS\Api\V1\Api->call() #6 C:\whmcsdev.test\modules\widgets\Health.php(23): localAPI('GetHealthStatus', Array) #7 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Module\AbstractWidget.php(0): WHMCS\Module\Widget\Health->getData() Edited October 21, 2021 by GhostRider 0 Quote Link to comment Share on other sites More sharing options...
GhostRider Posted October 21, 2021 Author Share Posted October 21, 2021 Oops! Something went wrong and we couldn't process your request. Please go back to the previous page and try again. For additional assistance, please reference the WHMCS TroubleShooting Guide » TypeError: Return value of WHMCS\Support\TicketMask::gatherMaskPossibilities() must be of the type int, float returned in C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Support\TicketMask.php:0 Stack trace: #0 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\View\Admin\HealthCheck\HealthCheckRepository.php(0): WHMCS\Support\TicketMask->gatherMaskPossibilities() #1 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\View\Admin\HealthCheck\HealthCheckRepository.php(0): WHMCS\View\Admin\HealthCheck\HealthCheckRepository->checkTicketMask() #2 C:\whmcsdev.test\includes\api\gethealthstatus.php(0): WHMCS\View\Admin\HealthCheck\HealthCheckRepository->nonKeyChecks() #3 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Api\V1\Api.php(0): unknown() #4 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Api\V1\Api.php(0): WHMCS\Api\V1\Api->executeApiCall() #5 C:\whmcsdev.test\includes\functions.php(0): WHMCS\Api\V1\Api->call() #6 C:\whmcsdev.test\modules\widgets\Health.php(23): localAPI('GetHealthStatus', Array) #7 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Module\AbstractWidget.php(0): WHMCS\Module\Widget\Health->getData() #8 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Module\AbstractWidget.php(0): WHMCS\Module\AbstractWidget->fetchData(false) #9 C:\whmcsdev.test\templates_c\fc6958cbc46fddb7b9de21efac33a6500145cc72_0.file.homepage.tpl.php(145): WHMCS\Module\AbstractWidget->render() #10 C:\whmcsdev.test\vendor\smarty\smarty\libs\sysplugins\smarty_template_resource_base.php(123): content_61711cb55f85b7_80284528(Object(Smarty_Internal_Template)) #11 C:\whmcsdev.test\vendor\smarty\smarty\libs\sysplugins\smarty_template_compiled.php(114): Smarty_Template_Resource_Base->getRenderedTemplateCode(Object(Smarty_Internal_Template)) #12 C:\whmcsdev.test\vendor\smarty\smarty\libs\sysplugins\smarty_internal_template.php(216): Smarty_Template_Compiled->render(Object(Smarty_Internal_Template)) #13 C:\whmcsdev.test\vendor\smarty\smarty\libs\sysplugins\smarty_internal_templatebase.php(232): Smarty_Internal_Template->render(false, 0) #14 C:\whmcsdev.test\vendor\smarty\smarty\libs\sysplugins\smarty_internal_templatebase.php(116): Smarty_Internal_TemplateBase->_execute(Object(Smarty_Internal_Template), NULL, NULL, NULL, 0) #15 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Smarty.php(0): Smarty_Internal_TemplateBase->fetch('blend/homepage....', NULL, NULL, NULL, false, true, false) #16 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Admin.php(0): WHMCS\Smarty->fetch('blend/homepage....') #17 C:\whmcsdev.test\vendor\whmcs\whmcs-foundation\lib\Admin.php(0): WHMCS\Admin->output() 0 Quote Link to comment Share on other sites More sharing options...
