maritimesbob Posted December 28, 2007 Share Posted December 28, 2007 I was having a few issues with my current whmcs install, particularly problems where clients could not login, they were seeing blank pages. I figured maybe one or two files were corrupted so it was a good opportunity to upgrade. I ran the install/upgrade script which completed, however now I cannot login or access whmcs at all. All I get is: "An upgrade is currently in progress... Please come back soon..." Thanks. 0 Quote Link to comment Share on other sites More sharing options...
Brett Posted December 28, 2007 Share Posted December 28, 2007 Did you delete the install folder? Also I remember reading where some people were having to run through the installer twice. 0 Quote Link to comment Share on other sites More sharing options...
Gav Posted December 28, 2007 Share Posted December 28, 2007 I had the same, I went to domain.com/install/install.php like it said to in the upgrade instructions and it only gave me an option to install and not upgrade. I backed up my database and went for it. It cleared all of my settings (luckily it didn't delete any accounts or services) and now the system can't send out emails. 0 Quote Link to comment Share on other sites More sharing options...
maritimesbob Posted December 28, 2007 Author Share Posted December 28, 2007 I had the same, I went to domain.com/install/install.php like it said to in the upgrade instructions and it only gave me an option to install and not upgrade. I backed up my database and went for it. It cleared all of my settings (luckily it didn't delete any accounts or services) and now the system can't send out emails. That`s what happened, there was no upgrade option only "new installation" or something like that. My mistake because I continued to proceed and it ended up cleaning out my database!!! I have to dig out a copy of my database, reinstall that and see what happened. 0 Quote Link to comment Share on other sites More sharing options...
Gav Posted December 28, 2007 Share Posted December 28, 2007 I've restored my backup and changed tblconfiguration - Version to 5.2.1 But the system is not sending out emails. And to top it off, someone has deleted the support ticket that I opened! 0 Quote Link to comment Share on other sites More sharing options...
