two instances of same product
i set up spamexperts in/outbound bundle for my client. Since it was my first time when I tried provisioning i didn't realize i had to add points and it didnt work. I added points, did it again and the 2nd time provisioned properly. However the first attempt is still listed under products / services.  When i try to 'terminate' the addon it says 'Module Command Error
You must provision this service before attempting to manage it'.
pls advise what to do to remove this thanks
  • 2 months later...
