namoos Posted June 19, 2019 Share Posted June 19, 2019 Hi, I am implementing the AddOrder API, a bit confused by the configoptions. Actually I am unable to make a proper request. In the order there are configurable options like physical servers and tiers etc. In the below product I need 2 configurable options, "physical_server_tier" and "physical_servers", according to docs the code should look like this. "configoptions" => [base64_encode(serialize([ '12' => 2 // quantity of the physical servers '11' => 27 ]))], but this is not working. Any help would be much appreciated. array:3 [▼ "id" => 8 "name" => "R1Soft License Key" "options" => array:7 [▼ "physical_tier_lock" => array:3 [▶] "physical_server_tier" => array:3 [▼ "id" => 11 "name" => "Physical Server Tier" "options" => array:8 [▼ 0 => array:4 [▼ "id" => 27 "name" => "tier-0" "currency" => "USD" "pricing" => array:3 [▶] ] 1 => array:4 [▶] 2 => array:4 [▶] 3 => array:4 [▶] 4 => array:4 [▶] 5 => array:4 [▶] 6 => array:4 [▶] 7 => array:4 [▶] ] ] "physical_servers" => array:3 [▼ "id" => 12 "name" => "Physical Servers" "options" => array:1 [▼ 0 => array:4 [▼ "id" => 35 "name" => "Physical Servers" "currency" => "USD" "pricing" => array:3 [▶] ] ] ] "virtual_tier_lock" => array:3 [▶] "virtual_machine_tier" => array:3 [▶] "virtual_machines" => array:3 [▶] "license_key" => array:3 [▶] ] ] 0 Quote Link to comment Share on other sites More sharing options...
Kian Posted June 19, 2019 Share Posted June 19, 2019 You should post your script since the array you posted probably comes from another system and let us know if you need to use External or Internal API. Here you find all information (use as reference the provided code). Don't forget that the Product/Service you're trying to add must exist on your WHMCS with Configurable Options you need. 0 Quote Link to comment Share on other sites More sharing options...
namoos Posted June 20, 2019 Author Share Posted June 20, 2019 @Kian Thanks for your reply. I am receiving this product/service from this API and submitting it via the api you mentioned "AddOrder". It creates an order at the WHMCS, but the configurable options are missing as I have pointed out in the above attachment. Below is the code I am using. if ($input['package'] == 45) { $product = $packages['license']; $config_options = [ base64_encode(serialize([ $product['options']['physical_servers']['id'] => (int)$input['agents'] ])) ]; $product_options = $product['options']['license_key']['options']; } $selected_package = null; foreach ($product_options as $record) { if ($input['package'] == $record['id']) { $selected_package = $record; break; } } // Package price $package_price = 0; if ($input['term'] == 'monthly') { $package_price = $selected_package['pricing']['monthly']; } else { $package_price = $selected_package['pricing']['annually']; } // Setup price $setup_price = 0; if ($input['setup'] == 1) { $setup_price = 24.95; } // Addons prices $tier_price = 0; if ($input['package'] == 45) { $tiers = $packages['license']['options']['physical_server_tier']['options']; if ($input['term'] == 'monthly') { $tier_price = $tiers[0]['pricing']['monthly'] * $input['agents']; } else { $tier_price = $tiers[0]['pricing']['annually'] * $input['agents']; } } $total_price = $package_price + $setup_price + $tier_price; $response = $this->client->request('POST', $this->api_url, [ 'form_params' => [ 'action' => $this->commands['place_order'], 'username' => $this->api_identifier, 'password' => $this->api_secret, 'clientid' => $client_id, 'pid' => $product['id'], 'billingcycle' => $input['term'], 'configoptions' => $config_options, 'paymentmethod' => 'paypalbilling', 'clientip' => $_SERVER['REMOTE_ADDR'], 'priceoverride' => round(floatval($total_price), 2), 'responsetype' => 'json', ] ]); $result = json_decode($response->getBody()); 0 Quote Link to comment Share on other sites More sharing options...
