Integration with Post Affiliate Pro (checkoutscript.php) hangs
nerdudes
We are trying to integrate Post Affiliate Pro with WHMCS. Between us and the support people from Quality Unit We have tried a variety of ways of placing their code in checkoutscript.php. However the check out process through ordering gets hung in the checkout part. I was wondering if anyone else experienced these problems and how to get around it. the following are two examples of different codes that we have tried:
method #1 code in checkoutscript.php:
<?php
************** WHMCS CheckOut Script *************
You may enter code here which will be run when
a user checks out if you have enabled it in
Configuration > General Configuration > Other
of your WHMCS Admin Area. The following
variables are available to you:
Order ID: $orderid
Order Number: $ordernumber
Invoice ID: $invoiceid
Product ID: $productid
Domains Array: $domains
Addons Array: $addons
// You got mail!
mail($emailto, $subject, $message, $headers);
$result=mysql_query("SELECT * FROM tblorders WHERE ordernum = '$ordernumber' LIMIT 1");
$row = mysql_fetch_array($result);
$amount = $row['amount'];
<script id="pap_x2s6df8d" src="http://affiliates.webservio.biz/scripts/sale.js" type="text/javascript"></script>
<script type="text/javascript">
var TotalCost="<?php echo $amount ?>";
var OrderID="<?php echo $orderid ?>";
var ProductID="";
papSale();
</script>
method #2 in checkoutscript.php:
<?php
Order ID: $orderid
// You got mail!
$result = file_get_contents("http://affiliates.webservio.biz/scripts/sale2.php?TotalCost=".$amount."&OrderID=".$ordernumber."&aid=".$_COOKIE['POSTAff2Cookie']);
Also their integration general code to insert in shopping carts is:
<script type="text/javascript"><!--
var TotalCost="XXXXXX.XX";
var OrderID="XXXXXX";
var ProductID="XXXXXX";
papSale();
--></script>
We appreciate any help or hints we can get.
Mishi
  • 1 year later...
