Problem with server module configoptions
stroebs_za
Hi all,
I'm having great difficulty with configoptions in my custom server module. There is a phantom configoption showing up as configoption1 and has completely offset my configuration and broken all of my module deployments.
How can I find out where this is being injected?
Here is my module code:
function rise_ConfigOptions()
    // Should return an array of the module options for each product - maximum of 24.
    $configarray = array(
        "language" => "english",
        'package'        => array(
                             'FriendlyName' => 'Package Name',
                             'Type'         => 'text',
                             'Size'         => '25',
                             'Description'  => 'What will you name this amazing package?',
        'quota'          => array(
                             'FriendlyName' => 'Quota',
                             'Type'         => 'text',
                             'Size'         => '15',
                             'Description'  => 'Gigabytes of space allowed for the user. \
                             Needs to be a number!',
        'bandwidth'      => array(
                             'FriendlyName' => 'Bandwidth',
                             'Type'         => 'text',
                             'Size'         => '15',
                             'Description'  => 'Gigabytes of bandwidth allowed Needs to be a number!\
                             (0 for unlimited)',
        'type'           => array(
                             'FriendlyName' => 'Type',
                             'Type'         => 'dropdown',
                             'Options'      => 'dedicated,shared',
                             'Description'  => 'is this a shared seedbox or a dedicated one?\
                             RiSE = shared. RFSS = dedicated',
        'iptype'         => array(
                             'FriendlyName' => 'IP Type',
                             'Description'  => 'Is this the only user on the IP or will they be sharing it?\
                             Overiden by server settings.',
        'services'       => array(
                             'FriendlyName' => 'Additional Services',
                             'Type'         => 'text',
                             'Size'         => '100',
                             'Description'  => 'Should this package install certain services on the server?',
        'torrent_config' => array(
                             'FriendlyName' => 'Torrent Client Configuration',
                             'Type'         => 'textarea',
                             'Rows'         => '5',
                             'Cols'         => '50',
                             'Description'  => 'custom torrent configuration excluding SCGI port and RPC mount.\
                             ie. .rtorrent.rc. Leave blank for default.',
    return $configarray;
}//end rise_ConfigOptions()
