Problem between WHMCS / Plesk
  • WHMCS Technical Analyst III
Thank you for your post!
This means the username under the client's Products/Services tab is empty.
You should enter a username, save changes and try module creation again.
Also, ensure Setup > Products/Services > Products/Services > Edit > Require Domains is ticked to avoid this in future.
I hope this helps.
