Desperadouz Posted October 2, 2016 Share Posted October 2, 2016 Hello Guys, I Have Smarty problem in WHMCS 6.3.1 My Module Use php tags {php} in .TPL Files, So i used SmartyBC Insted of Smarty, But Now I Get This Error : Fatal error: Using $this when not in object context in D:\xampp\htdocs\whmcs\vendor\smarty\smarty\libs\SmartyBC.class.php(464) : eval()'d code on line 1 My Code : <div id="tabs"> <ul> <li class="tab tabselected" id="tab0"><a href="javascript:;">{php}echo sprintf($this->_tpl_vars['_lang']['discount_tab_title'],$this->_tpl_vars['_lang']['hostingaccount']);{/php}</a></li> <li class="tab" id="tab1"><a href="javascript:;">{php}echo sprintf($this->_tpl_vars['_lang']['discount_tab_title'],$this->_tpl_vars['_lang']['reselleraccount']);{/php}</a></li> <li class="tab" id="tab2"><a href="javascript:;">{php}echo sprintf($this->_tpl_vars['_lang']['discount_tab_title'],$this->_tpl_vars['_lang']['server']);{/php}</a></li> <li class="tab" id="tab3"><a href="javascript:;">{php}echo sprintf($this->_tpl_vars['_lang']['discount_tab_title'],$this->_tpl_vars['_lang']['domains']);{/php}</a></li> </ul> </div> And : {php} for($this->_tpl_vars['page']=1;$this->_tpl_vars['page']<=$this->_tpl_vars['totalpages'];$this->_tpl_vars['page']++){ {/php}<option value="{$page}"{if $page==$pagenumber} selected="selected"{/if}>{$page}</option>{php} } {/php} Can You Help Me To Fix Problem ? Like This Topic : https://forum.whmcs.com/showthread.php?104675-whmcs-v6-0-1-template-php-problem 0 Quote Link to comment Share on other sites More sharing options...
twhiting9275 Posted October 3, 2016 Share Posted October 3, 2016 Fatal error: Using $this when not in object context in D:\xampp\htdocs\whmcs\vendor\smarty\smarty\libs\SmartyBC.class.php(464) : eval()'d code on line 1 Can You Help Me To Fix Problem ? Don't use Windows. Problem solved I'm not sure if that'll solve all of your problems, but that's one huge issue. WHMCS no longer supports Windows servers, hasn't for a year or so now. Aside from that, since you're using smartybc, you will likely have to consult with their support. Using {php} tags in smarty is pretty taboo, however, it has been for years. You need to find a way to incorporate action hooks, instead of direct php calls. 0 Quote Link to comment Share on other sites More sharing options...
