david_reid Posted January 17, 2016 Share Posted January 17, 2016 Hello, I have a tutoring company and I will be using WHMCS to take payments and manage the students e.t.c. I have a few questions: How can I remove the 'Hosting' features like Network Status, for example? Are there any free templates that aren't hosting related? Thanks! David 0 Quote Link to comment Share on other sites More sharing options...
sentq Posted January 17, 2016 Share Posted January 17, 2016 hello David, 1. You can simply remove any link you do not need in your WHMCS installation using ActionHook (example code available here in the forum) and/or delete these files too. 2. I think the answer is no, but you can get any free/paid template you like and integrate it with WHMCS. 0 Quote Link to comment Share on other sites More sharing options...
david_reid Posted January 17, 2016 Author Share Posted January 17, 2016 hello David, 1. You can simply remove any link you do not need in your WHMCS installation using ActionHook (example code available here in the forum) and/or delete these files too. 2. I think the answer is no, but you can get any free/paid template you like and integrate it with WHMCS. Thank You very much! I get searching on how to use ActionHooks! David 0 Quote Link to comment Share on other sites More sharing options...
