xtranet Posted September 29, 2015 Share Posted September 29, 2015 good day, we use a package called coza epp to maintain our co.za tld domains. it lacks the ability to add glue records for a domain, is there anyone that can help out with this or recommend and alternative that works? thanks. 0 Quote Link to comment Share on other sites More sharing options...
wsa Posted September 29, 2015 Share Posted September 29, 2015 We have developed several registrar modules based on EPP protocol also you can contact me here 0 Quote Link to comment Share on other sites More sharing options...
SilverNodashi Posted October 1, 2015 Share Posted October 1, 2015 @xtranet, I suggest you look at some of the South African posts since the ZACR / Uniforum standards are a bit different. There are 3 (I think) coza EPP modules available already, perhaps you can look into that? 0 Quote Link to comment Share on other sites More sharing options...
