Possible Cart Issue
Sliffer21
Strange because our theme was based of the Six template set (Via Professional Integration Service) so I am not sure why it is affecting one new order form and one older order form. But thanks as a test I replaced our custome Header.tpl with the updated six theme tpl. I will work on getting the changes made to ours.
@tsiedsma
Your code replacement seemed to help however this removes the outside side menu not the inner (smaller) one that seems to be the issue since the update. Do you happen to know the file which the location of the inner sidebar is located?
You likely have a custom cart template and need to edit it. I would look for a similar line of code in your tpl files.
We don't run a custom cart template just main theme, the changes you have suggested do remove one duplication of the menu however it leaves a large blank space (Where the menu should be) and nests the duplicated menu in the area that holds the products.
Basically it eliminates the two menu issue, just the wrong menu. It removes the original menu not the duplicate menu.
@web2008,
No, I contacted WHMCS about this since it was affecting old and new cart templates and their result was ask me if I want to pay $10 to upgrade our template to the newest 6.1 version. Considering I just paid them at the end of July for 6.0 integration and then kept finding things they missed, we didn't get it working until August without issues, this pushed me a little to far. I know $10 isn't much at all and I am willing to pay it just for them to fix all the issues we are having in the templates but considering the last $35 got us around a month of a working template I am feeling more and more like they are going to tweak the themeing every release to get a license like income from the theme integration service.
seems you fixed it?? - Ah I guess not, you just removed the outer sidebar!
anyone else getting the issue, Just follow the upgrade instructions for 6.1,
I had the same issue, but managed to fix it :)
http://puu.sh/klXdb/b0f57ffcda.png
I even added the "featured" option to the style, since it isn't default ;)
Edited by Martyn
