help required in License
meudayg1
Hi All,
I'm new here and need help in adding license code to my script which will go public in few days.
I want to use below parameters for my script just want to make sure nothing break the license code
$localkeydays = 5;
$allowcheckfaildays = 5;
$localkeyvalid = true;
1. what will happen if i change value to "FALSE"
If my license server goes down/maintenance will the script live or it will also goes down? (assuming value True)
Please help me
hello,
$localkeydays = 21; what can be max days?
how many days before next validation request, the software will connect to your server to check if everything is valid and active.
$allowcheckfaildays = 16; what does this do?
If $localkeydays period completed and software tried to connect to your server, but the connection was fail, how many days to allow the software to run before it try to validate again.
$localkeyvalid = false; ==> What will happen if i change value to True
you need to keep it false (default), it's value will be changed during validation
