Alessa76 Posted July 14, 2015 Share Posted July 14, 2015 Hello, Since I had updated to WHMCS 6 the Cron is not working I have received this email message intead the Cron Daemon pipe.php <br /> <b>Warning</b>: main(/home/*******/init.php): failed to open stream: No such file or directory in <b>/home/*******/whmcs_crons/pipe.php</b> on line <b>0</b><br /> <br /> <b>Fatal error</b>: main(): Failed opening required '/home/*******/init.php' (include_path='.:/opt/php54/lib/php') in <b>/home/*******/whmcs_crons/pipe.php</b> on line <b>0</b><br /> cron.php Unable to communicate with the WHMCS installation. Please verify the path configured within the crons directory config.php file. My config.php <?php # Enter path to root WHMCS directory (relative or full) $whmcspath = '/home/*******/public_html/*******/'; ?> Any ideas? Somebody have the same issue? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
sentq Posted July 14, 2015 Share Posted July 14, 2015 check this answer! http://forum.whmcs.com/showthread.php?103090-Problem-with-Cron-WHMCS-6&p=426182#post426182 0 Quote Link to comment Share on other sites More sharing options...
Alessa76 Posted July 21, 2015 Author Share Posted July 21, 2015 Hello Sentq thanks I tried with **** /opt/php53/bin/php-cgi -q /home/xxxxxxxx/whmcs_crons/cron.php but I keep getting error : ( Any ideas? Somebody have the same issue? Thanks. 0 Quote Link to comment Share on other sites More sharing options...
iHOST.bg Posted August 25, 2015 Share Posted August 25, 2015 Hello. I had the same issue. You have to edit the config.php file within your crons folder (/name/public_html/whmcs/crons/config.php): <?php # Enter path to root WHMCS directory (relative or full) $whmcspath = '/name/public_html/whmcs/'; ?> Use the absolute path for your installation. BR, T. 0 Quote Link to comment Share on other sites More sharing options...
