currency problem
saudisoftech
Gateway accepted only dollar so i want when user pay invoice automatically convert my invoice price to dollar and then easily paypal or 2checkout will work
Now my whmcs system is running properly i have only one big issue my all products payment in Riyal but all payment gateway not accepted riyal so i need only once invoice is created and use goes to pay invoice automatically my invoice will convert to dollar and send to payment gateway so gateway do process easily give me some suggestion on this topic
to solve this you need to follow simple steps,
1) add USD as second currency in your WHMCS installation:
http://docs.whmcs.com/Currencies#Adding.2FEditing_a_Currency
2) after that go to " Setup > Payments > Payment Gateways ", inside your gateway configuration options you can find a new dropdown select called "
Convert To For Processing
" this is where you can choose "USD", then "Save Changes".
so when you try to add new order WHMCS will convert the invoice total from Riyal to USD while redirecting you to payment gateway to pay.
i hope this was clear answer to you
