websavers Posted April 10, 2015 Share Posted April 10, 2015 (edited) When using the Project Management Add-On admin dashboard widget, if a project does not have a due date set, the "Days Left / Due In" column indicates that it was due more than 736,000 days ago. Presumably it is telling me the number of days since Unix timestamp 0. It should probably say "No Due Date" when no date has been set. Also, given that these widgets have such limited space, it doesn't really make sense to show both the Due Date and Days left... one can be calculated from the other. I recommend using just one of those columns. It might be nice to be able to choose this in the Project Management settings pane. It would also be nice to be able to choose which tab is default (between My Assigned and Due Projects). Edited April 10, 2015 by jas8522 0 Quote Link to comment Share on other sites More sharing options...
