Help with Limiting Product IDs to IP hook
Serenade
I found this hook to limit one account per IP. It works perfectly, except I would like to limit it only to specific products (pid=1, and pid=2).
If anyone has any ideas and are willing to help it'd be greatly appreciated!
<?php
if (!defined("WHMCS")) die("This file cannot be accessed directly");
function checkIPIsValid($vars) {
$result = select_query("tblorders","id",array("ipaddress"=>$_SERVER['REMOTE_ADDR']));
if (mysql_num_rows($result) != 0) {
  return  "It looks like your IP has already been used to register an account.";
add_hook("ClientDetailsValidation",1,"checkIPIsValid");
if the above code work for then this modification will do too,
<?php
   $result = full_query("SELECT `tblorders`.`userid` FROM `tblorders`,`tblhosting` WHERE `tblorders`.`ipaddress`='".addslashes($_SERVER['REMOTE_ADDR'])."' AND `tblorders`.`id`=`tblhosting`.`orderid` AND `tblhosting`.`packageid` IN (1,2)");
Thanks for the quick reply! It looks like the hook is properly checking if the IP exists, however it seems the hook is limiting all of my Products IDs and not just 1 and 2. I only want the hook to stop if the order is for Product 1 or 2. If the order is product 3 or anything else, the order should proceed.
Thanks a lot!
<?php
Edited by Serenade
Typo
