order cart issue
Gazza
Hello
I have just upgraded to the latest version but having a issue with order cart.
if you try to add funds or pay an invoice or when clicking order now on any product it gives you a server 500 error.
I have enabled error reporting and it shows this error
Fatal error: Cannot redeclare loadgatewaymodule() in /chroot/home/host/mydomain.co.uk/html/clients/includes/gatewayfunctions.php on line 14
have requested support but no reply yet, so thought I would try here
if anyone has any ideas
thank you
  • 1 month later...
I disabled xcache for just the site I use with whmcs, all the other websites on the server are still using xcache
I added to .htaccess
# turn xcache off
php_flag xcache.cacher Off
php_flag xcache.size 0
php_flag xcache.stat Off
surprised this issue has not been patched by now
thanks for your reply
  • 10 months later...
I couldn't add the flags you mentioned it caused my server to crash with a 500 error.
I did disable xcache and still had problems, so finally a guy from cPanel took a look at it and I posted the information he gave me here: http://forum.whmcs.com/showthread.php?110447-Issue-with-unpaid-invoices
Sharing this so that some other person doesn't lose their mind trying to solve this.
  • 1 month later...
# turn xcache off
Thanks! it also solved my problem. :)
