ccdave Posted June 30, 2014 Share Posted June 30, 2014 All, Newbie to WHMCS and need some advice please on how to configure this. We supply support contracts to clients, all clients hve different prices for support depending on their equipment and needs. They would never buy this online but I want to bill everything through WHMCS. How would do I this? Would I add a product thats hidden or can just manually add it to a client? How do I give each client different pricing? The product nae itself would always be the same. Thanks in advance Dave 0 Quote Link to comment Share on other sites More sharing options...
PascM Posted July 1, 2014 Share Posted July 1, 2014 Hi, You can create a quote for a client and then transfer that quote to an invoice! That will help you! Regards 0 Quote Link to comment Share on other sites More sharing options...
durangod Posted July 1, 2014 Share Posted July 1, 2014 You can also create client groups http://docs.whmcs.com/Client_Groups although im not sure how that would work because your not using slabs such as in registrar pricing. I think you can still give groups pricing breaks from the product end. 0 Quote Link to comment Share on other sites More sharing options...
ccdave Posted July 1, 2014 Author Share Posted July 1, 2014 Thank you for the replies. I think I have found the solution in billable items? I have a lot of current contracts I have to move into the system. Does that sound the best way to go? 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Ryan Posted July 2, 2014 Share Posted July 2, 2014 Hello ccdave, If the invoice is one-off, custom created, per client invoice then billable items would a way to accomplish this task. To learn more about billable items please see - http://docs.whmcs.com/Billable_Items --Thanks 0 Quote Link to comment Share on other sites More sharing options...
