Problem when upgrading a package with configurable options
ddenev
Hi, let's assume the following example:
I have 2 packages: P1 ($50) and P2 ($70).
P1 has 2 configurable options - P1C1 ($6) and P1C2 ($8)
P2 has 3 configurable options - P2C1 ($10), P2C2 ($12), and P2C3 ($14)
(the prices in parentheses are monthly prices)
I have enabled P1 to be upgradeable to P2 (disabled upgrading the configurable options).
Let's say a client buys P1 with P1C1 (the price is $56). Then he decides to upgrade to P2 (for simplicity in price calculations let's assume he does this on the same day he bought P1). The upgrade summary page shows a total of $20 (which is $76 - $56, i.e. P2+P1C1 minus P1+P1C1). But this is not correct IMHO because there is no configurable option P1C1 in P2 package. I think it should be $14 ($70 - $56) to upgrade to a clear P2 package. And then allow users to choose config options for the new package (if there are any).
Now the customer is charged $6 more (for P1C1) and in the admin area this product is shown as P2 with no configurable options.
I hope this example makes it clear what I encountered.
Thank you.
I think that WHMCS should not calculate prices for config options which are not present in the package being upgraded to.
The problem is - the recurring amount for the new package is equal to ['new package' price] + ['config. option from previous package' price] even when the new package doesn't have this config option.
I hope it's clearer now :). Thank you.
