Accent problems in Massmail tool
mouseimaging
I upgraded WHMCS to version 5.2.5 and since then I have problems sending Mass Mail with the integrated tool.
I'm using accents (it's in french) and when I want to visualise the mailing (before sending it) I see just a small part of the mailing. Actually it stoppes at the word before the one with accent.
Do you know about this problem and how I can fix it ?
Thank you for your help.
Mouse Imaging
Paolo
