gateway payment problem
Michael Baks
Have you checked your settings here
Setup > general setup > ordering
There is a radio button option to auto redirect on checkout.
Thanks for tip but the problem is not in hire. Does have brought me the idea of a workaround for time being
Bug reports should be reserved for legitimate bugs. If you have a technical issue, please use the Technical Issue forum section.
I've moved this post.
Oke sorry for the wrong post. My bad
Are there people with different ideas where the problem may lie?
