LeoCash Posted April 19, 2013 Share Posted April 19, 2013 How can I get images to show up on the order page like this: https://www.daemonservers.co.uk/cart.php 0 Quote Link to comment Share on other sites More sharing options...
Cape Dave Posted April 20, 2013 Share Posted April 20, 2013 Great question, nicely done. 0 Quote Link to comment Share on other sites More sharing options...
jissh Posted April 20, 2013 Share Posted April 20, 2013 WHMCS allows for basic html to be used for product/service descriptions. Simply using htnl to call the image should have the desired effect. 0 Quote Link to comment Share on other sites More sharing options...
WHMCS Chris Posted April 20, 2013 Share Posted April 20, 2013 How can I get images to show up on the order page like this: https://www.daemonservers.co.uk/cart.php Have you taken a gander at our blog? http://blog.whmcs.com/insights.php?t=66227 0 Quote Link to comment Share on other sites More sharing options...
mlew2 Posted April 20, 2013 Share Posted April 20, 2013 (edited) Not sure if this helps any but here is the link to their images /https://www.daemonservers.co.uk/templates/orderforms/DSUK2/img/2.jpg give you an idea where to start at least also look at the page source that will help you out too Edited April 20, 2013 by mlew2 0 Quote Link to comment Share on other sites More sharing options...
LeoCash Posted April 20, 2013 Author Share Posted April 20, 2013 WHMCS allows for basic html to be used for product/service descriptions. Simply using htnl to call the image should have the desired effect. What would I type there to link to the image? 0 Quote Link to comment Share on other sites More sharing options...
MemoryX2 Posted April 21, 2013 Share Posted April 21, 2013 What would I type there to link to the image? <img src="where_ever_file_is_located.whatever" /> 0 Quote Link to comment Share on other sites More sharing options...
LeoCash Posted April 28, 2013 Author Share Posted April 28, 2013 That did not work... 0 Quote Link to comment Share on other sites More sharing options...
MemoryX2 Posted April 28, 2013 Share Posted April 28, 2013 That did not work... It will if you do it right. Were using it on almost all of our products. Make sure you used the correct path. Also you have to type the file type in, ex .png. 0 Quote Link to comment Share on other sites More sharing options...
LeoCash Posted April 29, 2013 Author Share Posted April 29, 2013 https://www.ewehost.com/store/cart.php Doing exactly that, and not working. 0 Quote Link to comment Share on other sites More sharing options...
LeoCash Posted May 1, 2013 Author Share Posted May 1, 2013 Fixed. ............ 0 Quote Link to comment Share on other sites More sharing options...
