Project management blank page after 5.2.2 upgrade
dafky2000
Hey Guys,
After performing the WHMCS 5.2.2 upgrade last night my Project Management module has been inaccessible. I have tried a "clean install" (removed all database items, and let the module recreate) and I still get the same blank page symptom.
When I disable all Project management permissions I get the regular "Access has not been given for your admin role group to access this addon module.", but once I add the correct permission I get a completely blank page. No apache error_logs, no WHMCS debug or error logs regarding it, not sure where else to look.
Is anyone else having this issue?
Any help is greatly appreciated!
Thanks,
Dan
heh, after looking at the sticky, and turning on Display errors.... Here is the output:
Fatal error: Cannot access private property WHMCS_License::$keydata in /home/interapp/public_html/secure/modules/addons/project_management/project_management.php on line 0
  • 3 weeks later...
We are having the same issue. Did you find a resolution? We have spoken to IONCube and they checkout out our IONCube configuration and verified all is good. We are running the latest version of PHP and IONCube. We have reported the issue to WHMCS and gave access to our server but have had not a lot of response.
Yes, mine has been resolved, it did take a few days but they figured it out. The support team re-uploaded the files and that seemed to fix the issue, although I tried this many times before contacting them, it seemed to work for them. I have pasted the resolution response below, the support agent that fixed it was Kim.
Thank you for providing working login details.
I have now re-uploaded the files from the Project Management addon and you can now access this. Please login and check that everything is working as intended.
We appreciate your patience during this busy time for us after a new release.
If we can be of any more assistance please do not hesitate to ask.
Regards,
Kim
Customer Support
Glad to gear they basically had to fix something and then upload the files. Would be better if they just has either a release that fixed it or documentation for do it yourself. Hopefully they will resolve our issue officially. We had 3 add-ons that were not working. Chat, Project Management and Mobile. We started working on it without documentation to help since we had not been resolved by WHMCS after X number of days. We ended up semi downgrading by stealing files from previous versions and ended up getting Chat and Project Management to work. We still are not able to use Mobile.
