WHMCS-CSF Auto Unblocker v2.0 - Compatible with cPanel, DA, plus other systems
Are your clients, resellers or resellers' clients always locking themselves out from your server because of too many failed login attempts?
Is your help desk always filled with IP unblocking requests? Why not lessen your work load for you and your staff by cutting down your support ticket counts?
With the WHMCS-CSF Auto Unblocking Module you can now give the unblocking power to your hosting clients without compromising your server's security.
Stand out from the crowd! Let your customers know you care!
Module Features
  • Remote calls without needing SSH access (root access is needed initially to setup the permission/ownership for the files and the cronjob)
  • Root logins/passwords/keys are NOT kept by our module.
  • No special PHP extension/module is required
  • External access safe (Hash is checked before any task is executed)
  • Check Unlimited server
  • Check for both deny list (csf.deny) and temp ban list (csf.tempban)
  • Email notification to the admin when a CSF rule is being taken off the list
  • Configure remote servers within seconds using our automatic installer commands!
  • Regular hosting user and reseller hosting user mode (the mod will automatically get the IP of a regular hosting user, while reseller hosting user will have the option to search for a client's IP address in the block list)
  • Customizable template files + Template integration
  • Streamlined remote server installation (install modules on remote servers automatically *cPanel + Directadmin*) * NEW
  • Blocked explanation (explain what the error meant, and how your client could prevent it from happening again)
  • Server list syncing withing WHMCS (No need add individual servers manually)
  • Remote server connectivity checker - IMPROVED
  • Official Multi-Language support
  • Support all system running CSF, not just cPanel and DirectAdmin
  • All 4.x version of WHMCS is supported.
  • View full blocking list within WHMCS-Admin Area - NEW
  • Stop unblocking of admin added blockings - NEW
  • Remote server configuration checker - NEW
  • Remote Server Auto Installer for cPanel and DirectAdmin - NEW
Requirements:
  • Working installation of WHMCS
  • Root access (need for remote server setups, not needed for encoded module operations)
  • Two or more servers with CSF installed (the WHMCS installation should not reside on the same server as your clients)
  • Remote servers must be HTTP accessible
  • Cronjobs must be working on remote servers
  • mail() & system() must be enabled on remote servers (if system() is turned off, there is a workaround)
  • Remote server must not be running fcgi
Pricing Information:
Yearly Leased - $29.99 per year - [Order]
Owned with 6 months support + updates - $45.99 - [Order]
Additional 6 months of support + update is $5.99
If you have any questions, feel free to contact us
Screen Shot 1 - Admin Management
Screen Shot 2 - Reseller client
Screen Shot 3 - Regular Client
Screen Shot 4 - Client when suspended (checking disabled)
Screen Shot 5 - Blocked message (customizable)
Screen Shot 6 - Unblock success (customizable)
Screen Shot 7 - Advanced search message (customizable)
See the testimonials
Testimonial 1
Testimonial 2
