problem with Usage Summary
Cantres60
I think the answer is that whmcs now supports only cpanel 11, not 10.. but i may be wrong. I am saying this because we still have some servers with cpanel 10 and none returns that info.
Cheers,
Here's the thread where I asked and Matt replied just for verification:
http://www.whmcs.com/forums/viewtopic.php?t=5335'>http://www.whmcs.com/forums/viewtopic.php?t=5335
PPH
PostPosted: Sun Jul 22, 2007 5:11 pm Post subject: Reply with quote Edit/Delete this post
This is really sad it worked out this way. I am pleased as we are on CP11 but can see the problem here.
Would it have been possible to use a cp10 and a cp11 module? For instance, could the old module be used as a 2nd module and maybe referenced differently for those that need it?
_________________
best regards,
George
Back to top
View user's profile Send private message
Matt
WHMCS Staff
PostPosted: Sun Jul 22, 2007 5:33 pm Post subject: Reply with quote
Sure is - you can just take the module from V3.1.2.
Matt
_________________
WHMCS Staff
PPH
_________________
best regards,
George
Back to top
Matt
WHMCS Staff
Matt
_________________
WHMCS Staff
Great. Any idea if we can just rename the modules folders as cpanel_10 and cpanel_11
It works for creating accounts, but the disk summary is using some other file i think...
Cheers,
Right, i dont think matt consults the server modules for disk usage. Even though thats the way it should work.
Not at all. You're very quick to criticise all the time, but often wrongly in my opinion. And no, renaming the folders won't work.
