imtiax Posted June 11, 2012 Share Posted June 11, 2012 When I go to upgrade/downgrade an order in a clients profile. a pop up comes up and says The page is blank and says An Error Occurred When I click Generate due invoices it says Invoice Generation Complete 0 Invoices Created When I click Create Add Funds Invoice And add like $10 or any amount it says Create Add Funds Invoice The add funds invoice was created successfully! - Invoice #0 And when I click on Invoice #0, it goes to http://cryptic-hosting.com/x1/invoices.php?action=edit&id=0 Then it says Invoice #0 Invoice ID Not Found -- What is wrong with my WHMCS? 0 Quote Link to comment Share on other sites More sharing options...
disgruntled Posted June 12, 2012 Share Posted June 12, 2012 When I go to upgrade/downgrade an order in a clients profile. a pop up comes up and says The page is blank and says An Error Occurred When I click Generate due invoices it says Invoice Generation Complete 0 Invoices Created When I click Create Add Funds Invoice And add like $10 or any amount it says Create Add Funds Invoice The add funds invoice was created successfully! - Invoice #0 And when I click on Invoice #0, it goes to http://cryptic-hosting.com/x1/invoices.php?action=edit&id=0 Then it says Invoice #0 Invoice ID Not Found -- What is wrong with my WHMCS? Look in the general settings, i think its the last tab that has two check boxes, one for php errors one for mysql errors, this one seems like it may be php, so click to display php errors and start over doing all you described, once you have tangible error messages you will either know what to do immediately, else you will need to open a support ticket here at whmcs. once you have your answers, disable displaying of errors again, just a precaution for your security. Also have you updated with the recent patch? i know the first release of it broke systems in whmcs, so if you got it early as many did, repatch with the latest one. this might just fix your problem. 0 Quote Link to comment Share on other sites More sharing options...
