maritimer Posted February 24, 2012 Share Posted February 24, 2012 Having a bit of a problem setting up my products and getting the cart to play nicely. I am trying to test order a product using the Direct Shopping Cart link. It bring up the page for entering the domain, once the domain is entered and submit is hit it bring up the whole list of products for the particularly group. This doesn't seem right, if I am chosing the direct shopping cart link it should remain with that product id not bring up the whole group of products. Anyway, just for fun I select the product it should be on but the cart reverts back to the domain selection page. So, the direct cart url is: whmcslocation.com/cart.php?a=add&pid=2 however after chosing the domain and submitting it takes me to cart.php Hope I made some sense! 0 Quote Link to comment Share on other sites More sharing options...
Sitepearl Posted February 24, 2012 Share Posted February 24, 2012 Did you disable the "Require Domain" option for this product? 0 Quote Link to comment Share on other sites More sharing options...
maritimer Posted February 24, 2012 Author Share Posted February 24, 2012 Nope, the option is enabled. Thanks, 0 Quote Link to comment Share on other sites More sharing options...
maritimer Posted February 25, 2012 Author Share Posted February 25, 2012 Well this one has me perplexed. I have dropped a ticket into whmcs this morning. I had re-uploaded all files again, replaced any custom teplates with the default ones but the problem remains. I was thinking perhaps when I integrated whmcs into the site something went wrong but nope. I tried Portal and the other templates tried different cart templates too but all with the same result. The cart is not functioning correctly. Hopefully support can look into it. No doubt I have missed something obvious!!! 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted February 25, 2012 Share Posted February 25, 2012 Do you have register_globals turned on? 0 Quote Link to comment Share on other sites More sharing options...
maritimer Posted February 25, 2012 Author Share Posted February 25, 2012 Yep, it is indeed enabled. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
laszlof Posted February 25, 2012 Share Posted February 25, 2012 My next suggestion would be to check session.save_path in php.ini and make sure that the directory its set to is writable. 0 Quote Link to comment Share on other sites More sharing options...
maritimer Posted February 26, 2012 Author Share Posted February 26, 2012 The /tmp directory is writeable. Thanks. 0 Quote Link to comment Share on other sites More sharing options...
