Please help with custom client fields in invoice
wonderland
I did look through wiki and almost found everything I need , except one small thing.
I'm using this code in invoicepdf.tpl
if ($clientsdetails["customfields1"]) {
       $pdf->Cell(0,6,$clientsdetails["customfields1"],0,1,'L');
Which surely enough displays fieldvalue of customfield1
But I would like to display fieldname : fieldvalue
How could I do this ?
This question has been asked many times, to most this is difficult... Maybe a forum mod can can move this post to "Tips and Tricks"
Place this code at the top (under the <?php) of the invoicepdf.tpl
$result22a = mysql_query("SELECT `tblcustomfields`.`fieldname` , `tblcustomfieldsvalues`.`value` FROM tblcustomfields, tblcustomfieldsvalues WHERE `tblcustomfields`.`id` = `tblcustomfieldsvalues`.`fieldid` AND `tblcustomfields`.`type` = 'client' AND `tblcustomfieldsvalues`.`relid` = {$clientsdetails['userid']}");
while ($data22a = mysql_fetch_assoc($result22a)){
   $clientsdetails["customfields"]["{$data22a["fieldname"]}"]["fieldname"] = $data22a["fieldname"];
   $clientsdetails["customfields"]["{$data22a["fieldname"]}"]["value"] = $data22a["value"];
As an example the array will be added to the clientsdetails array like this
Array
   [userid] => 1
   [id] => 1
   [firstname] => Test
   [lastname] => Tester
   [companyname] =>
   [email] => REMOVED
   [address1] => REMOVED
   [address2] =>
   [city] => REMOVED
   [state] => Queensland
   [postcode] => 4280
   [country] => Australia
   [countryname] => Australia
   [phonenumber] => 0123456789
   [notes] => You have unpaid invoices... pay now to avoid suspension of your account
   [password] => REMOVED
   [currency] => 1
   [defaultgateway] => banktransfer
   [cctype] =>
   [cclastfour] =>
   [securityqid] => 0
   [securityqans] =>
   [groupid] => 0
   [status] => Active
   [credit] => 0.00
   [taxexempt] =>
   [latefeeoveride] =>
   [overideduenotices] =>
   [separateinvoices] =>
   [disableautocc] =>
   [language] => english
   [lastlogin] => Date: 21/01/2012 15:05<br>IP Address: xxx.xxx.xxx.xxx<br>Host: xxx.xxx.xxx.xxx
   [customfields1] => 14123145125
   [customfields2] =>
   [billingcid] => 0
   [customfields] => Array
           [ABN] => Array
                   [fieldname] => ABN
                   [value] => 14123145125
           [Recieve Marketing Emails] => Array
                   [fieldname] => Recieve Marketing Emails
                   [value] =>
Then use it like this (going from the customfields array output above)
if ($clientsdetails["customfields"]["ABN"]) {
   $pdf->Cell(0,6,$clientsdetails["customfields"]["ABN"]["fieldname"]." : ".$clientsdetails["customfields"]["ABN"]["value"] ,0,1,'L');
Hope this has helped someone.
Edited by sparky
