Down for Maintenance when using integration code
Keksi
I'm trying to get a integrationcode to work in MODX.
What I'm trying to accomplish is:
If user is logged in = Show some links, etc.
If user is logged out = Show loginform.
I have tried so many scripts from this forum, but i cant really get anyone to work.
With the last one, i have actually got the integration halfway correct i think. The problem is that i get the standard whmcs "Down for Maintenance - Upgrade in progress" message.
This is the code I'm trying to use:
require("dbconnect.php");
if (!empty($GLOBALS['clientsdetails']['id']))
       require_once ("includes/clientfunctions.php");
       $userdetails = getclientsdetails($GLOBALS['clientsdetails']['id']);
   $firstname= $userdetails['firstname'];
if ($_SESSION['uid'] > 0) {
echo "<strong>Hello $firstname! You are logged in.</strong>   <a href=\"/logout.php\">(Click for Logout)</a>";
else
echo "Login form is put in here";
So:
1. Anyone have a clue on how i can resolve this?
2. Do i really need to include dbconnect.php, when both MODX and WHMCS is in the same DB?
When not including the dbconnect.php file, the script shows me the loginform, even when I'm actually logged in to the client area.
I dont know about modx, but the inclusion of dbconnect pulls in the required functions to use WHMCS.
Have you tried to var_dump $GLOBALS? I'm willing to bet that $GLOBALS['clientsdetails']['id'] is not set.
If they are indeed logged in, you can use $_SESSION['uid'] assuming that WHMCS is on the same domain.
Something like this maybe
require_once ("dbconnect.php");
if ((isset($_SESSION['uid'])) && ($_SESSION['uid'] > 0)) {
 $userdetails = getclientsdetails($_SESSION['uid']);
} else {
 // not logged in
Thanks for your reply.
When using this code, i still get the Down for Maintenance message.
When removing "require_once ("dbconnect.php");"
I get the logged out message.
If var_dump $GLOBALS can help understand whats wrong, how to i write that in a PHP code?
When using:
<?php
var_dump $GLOBALS
I get this message:
Parse error: syntax error, unexpected T_VARIABLE in /home/path-to-home-area/core/cache/includes/elements/modsnippet/44.include.cache.php on line 10
Witch is a part of MODX
Ok, i tried that now and copied the result to Notepad.
Length: 319679.......
I tried searching for "clientsdetails" and i got two results inside here:
$thread->remove(); } } break; } return;" ["locked"]=> string(1) "0" ["properties"]=> NULL ["disabled"]=> string(1) "0" ["moduleguid"]=> string(0) "" ["static"]=> string(1) "0" ["static_file"]=> string(0) "" } } ["sourceCache"]=> array(3) { ["modChunk"]=> array(0) { } ["modSnippet"]=> array(1) { ["WHMCSLogin"]=> array(3) { ["fields"]=> array(15) { ["id"]=> int(44) ["source"]=> int(1) ["property_preprocess"]=> bool(false) ["name"]=> string(10) "WHMCSLogin" ["description"]=> string(0) "" ["editor_type"]=> int(0) ["category"]=> int(0) ["cache_type"]=> int(0) ["snippet"]=> string(381) "require_once ("includes/clientfunctions.php"); if ((isset($_SESSION['uid'])) && ($_SESSION['uid'] > 0)) { $userdetails = getclientsdetails($_SESSION['uid']); $firstname= $userdetails['firstname']; echo "Hello $firstname! You are logged in. (Click for Logout)"; } else { // not logged in } var_dump($GLOBALS);" ["locked"]=> bool(false) ["properties"]=> array(0) { } ["moduleguid"]=> string(0) "" ["static"]=> bool(false) ["static_file"]=> string(0) "" ["content"]=> string(381) "require_once ("includes/clientfunctions.php"); if ((isset($_SESSION['uid'])) && ($_SESSION['uid'] > 0)) { $userdetails = getclientsdetails($_SESSION['uid']); $firstname= $userdetails['firstname']; echo "Hello $firstname! You are logged in. (Click for Logout)"; } else { // not logged in } var_dump($GLOBALS);" } ["policies"]=> array(1) { ["web"]=> array(0) { } } ["source"]=> array(6) { ["id"]=> int(1) ["name"]=> string(10) "Filesystem" ["description"]=> string(0) "" ["class_key"]=> string(26) "sources.modFileMediaSource" ["properties"]=> array(0) { } ["is_stream"]=> bool(true) } } } ["modTemplateVar"]=> array(0) { } } ["Event"]=> NULL ["stopOnNotice"]=> bool(false) ["pdo"]=> &object(PDO)#11 (0) { } ["config"]=> array(277) { ["access_category_enabled"]=> string(1) "1" ["access_context_enabled"]=> string(1) "1" ["access_resource_group_enabled"]=> string(1) "1" ["allow_forward_across_contexts"]=> string(0) "" ["allow_manager_login_forgot_password"]=>
But it looks like it is only showing exactly what i (you) wrote in the php script.
This is the script i used:
<?php
} else {
 // not logged in
var_dump($GLOBALS);
This was without including dbconnect.php, as if i do, I get the Down for Maintenance message.
